Engine has 135270 miles on it, no compression in cylinder 4. I'm the second owner purchased from 07MetallicSC in 2014 (https://www.cobaltss.net/forums/comp...alt-ss-304185/) Car is in Salem Oregon updated mod list below
Stock Options:
Laser Blue Metallic
2.0 L Ecotec LSJ Supercharged
High Rise Wing
Non G85
Black Leather Interior
Sunroof
- Second Owner-
Engine/Drivetrain:
Harrop TVS 1320 Supercharger
2.8" Pulley
Badmab Header
SMG Motoring 2.5" Downpipe
Corsa 2.5" Touring Catback
LNF Shifter Bracket
GMPP LSJ Clutch Upgrade
Upgraded Axles
GMPP Option B
SMG Motoring Dual Pass Endplate
SMG Motoring Front Mount Heat Exchanger
NGK BKR7E Plugs
RAW 3" Intake
K&N Oiled Filter
TTR Motor Mount
TTR Transmission Mount Inserts
ZZP Boost Referenced Fuel Pressure Regulator
Snow Performance Stage 2 Water/Methanol Injection with 2.5 Gallon Trunk Mount Setup (Boost Referenced)
Dynojet Tuned 315whp 275 wtq
Suspension:
H&R Sport Springs
Koni Yellow Adjustable Struts (F&R)
Powell Raceshop XXX Rear Swaybar
Powell Raceshop S-CABs
RAW Strut Bar
Powell Raceshop Steering Rack Spacers
Moog Strut Mounts
Moog Swaybar Endlinks
Powell Under Car Rails
Exterior:
MPX SS Style Carbon Fiber Hood with color matched sides
MPX Shorty Antenna
LED 3rd Brake Light
Color matched Projector headlights with 2 TRS bi-xenon 5k mini H1 retrofits, V3(?) vled Triton turn signals
TRS 5k Foglights
Colodude custom passat turn and brake with running light rings in the inner and outer tail lights
Tint
G2 Paint LBM Vin Matched Calipers (3 of 4)
Under-body sprayed with second skin spectrum to protect against rust
Interior:
Recaro front seats, Black leather rear seats
Genuine Saab Solid Shifter Bushings
24designs Transformer Steering wheel badge
CA Dual Pillar Pod Color Matched
CA Steering Column Pod
Aeroforce Interceptor Scan Gauge (red)
AEM Wideband Air/Fuel Gauge
OEM SS Turborcharged Boost Gauage
Carbon Fiber Dash Trim & color matched Dash trim
Color Matched Door Trim/Steering Wheel Trim
Audio:
Pioneer X9110bt Screen DVD/CD/Navigation/Blue tooth
Currently has a 5 channel amp I was installing. Will include if the price is right or wire to have audio for a little less.
Engine Dress Up:
Laser Blue Metallic Valve Cover
Powell Raceshop Wrinkle Black Coilpack Cover
I'm not really sure what a car in this condition would go for and since a price must be listed asking 3500 OBO
Reason: mobile site
Oooh a tvs huh? What was the situation for the lack of compression? Driving and it happened or what are the details? Just for a potentially buyer to know.
yup. Just driving from work one day and car didn't feel right. Next day went to get gas and it sounded/felt off again so I took it to the mechanic.
3500 for a car that needs a motor? Thats steep. My friend cant ever get someone to buy his lsj turbo for $1500 lol
that's where the obo comes in. Like I said I'm not sure the value of the car in this condition. To be honest I'm not sure if there's anyone local to get the car anyway... that's why I didn't do interior pics of anything like that
Tha sucks man, wish you could fix it and keep it but glws if you where in el Paso I would of gotten it off you
So do i man. Already bought a replacement but i would be down to have 2 cars or sell my fiancee's and teach her to drive stick on the new one. i can ship it to el paso quote to Connecticut was 1200
Absolutely no compression or just very low. To be zero you almost had to have blown a hole in a piston or burn a piston bad. Still... easy fix.
no idea man. Unfortunately engines are not my forte and im only going off what the mechanic i took it to told me. It starts and runs but it smokes really bad engine and exhaust.
yeah, new owner said hes had other things come up which i totally get 1000% percent. Its always in my head to msg him with an offer, but ive got enough on my plate between the house and the Cadillac
