For Sale FS/FT 2.0L ZZP Turbo Swap LSJ
Curious why you wouldn't part it out, seems like it would sell faster even if it would be more work on your end. Especially since you have a lot of desirable parts, except that 259..... No offense, most people would be afraid of the spool time for a daily driver even if it is a billet wheel or whatever it maybe. Charge pipes cha Ching, intercooler cha Ching, built motor cha cha Ching, wingless s trunk cha Ching, etc...... if i totalled my balt tomoroow i would definitely buy this car for asking price given the radio is put in, ac charged and working strong, and sc rims with good rubber all around are installed when I picked it up. Presentation and marketability is key., don't market to the less than 1% cobalt crowd, market to the majority.
You're running the same turbine housing I am lol. Spool is not bad. It's a 6mm larger compressor. Radio can be put back in. AC parts will come with but I will not be putting them on. Would need to re do the whole water pump setup for AC.
I could sell the turbo kit, but then I'd need an m62 kit. I could sell the engine, but then I'd need a stock engine. I could sell the wingless trunk, but then I'd need a trunk. I could put stock wheels on it, but I'd need to buy them.
Parting out is not going to happen. Too much work, same price, no return.
. Didn't know you had the same housing, that's a plus! I think I saw monograt427 have a sc kit for sale for 800 without heat exchanger. So say you buy a he for 200 and flashed your PCM to stock for free bc I'm pretty sure you have hpt. Now buy a stock header for less than 40 shipped which is what I've seen them go for and then source a catback. And say you scoop up a stock lsj cat back for 100 shipped. That's 800+200+100+140-300 for hpt youd sell it for=940. Plus rims which usually go for under 300 without tires so say 250. That puts you at 1190 plus some cheapo tires bc hey you are trading it in or selling it to some newb. You can easily make a a couple grand profit selling/trading a stock lsj engine for yours...bam you at least break even and can trade your built engine for a stocker plus cash. Now you have sc kit put on your car and stock engine plus cash in your wallet. You also still have your whole turbo arsenal to sell plus sell your car for 9-10k usd$ easily. Plus misc stuff that can be pulled from the car
Lol I'd give u my low mileage lsj engine. 25k on block. 1k on head. :P. Of course the car has 25k.
If you were to sell the turbo kit. Without the turbo. Like everything to lines and such how much would you ask.
93 may happen anyways once I get the new parts on since I want to go back to daily driving it. Going to shoot for the pump gas record again. And again with a non ported head.
The AC though will not be put on while I own it. The buyer will get all the parts, but it will be up to them to install it. I'm not going to reroute the coolant lines, buy and install an oem thermostat housing, buy and install a coolant pipe in the rear, move the water pump, install the compressor condensor and lines, order a new belt for the length, charge everything, remove the center radio bezel I made to reinstall the hvac controls, move the gauges from that bezel to a new location and then rewire them properly.
I MIGHT consider it for another $1k to cover the cost of the new parts, time off work, and my time doing everything listed above.
Turbo Johnny
Feb 21, 2019 09:41 AM
