DevilsOwn Brew sales
Ross, I can find pure meth near me for $3 per gallon.
Mix with 50/50 with distilled water and I have 10 gallons of meth mix for 1.50 per gallon as opposed to this meth "mix" which is 13.50 a gallon and you're really only getting 2 gallons of pure meth so in essence its $27.00 per gallon of meth
Yea shipping is a killer on this because of the weight. And i hate to say it the packageing cost more than the product. But we are 2/3 the price of what our comp is so i would say that is pretty fair.
Received my kit today. Im going to rip off the front bumper cover and install the pump inside the space where the tank is. Ill take pictures of this stealth install. Where is the best place for the nozzle in the charge pipe after the intercooler,after the sensor or before the sensor. I have plenty of room both sides.
Its all hooked up. I need to find a ignition on hot wire under the dash. I cant see a fuse box anywhere. I guess Ill have to use the old test light. I put the pump inside the drivers side fenderwell right next to the tank. Had to relocate the horn which was no problem. Ill post pics later.
I mounted my controller in the little box with the trunk popper. Thats why I was going to hook it up inside but I could hook it up in the fuse box I guess.
At least you're one of the companies offering it though!
Its hooked up except for the vacuum T which I will get after supper. Tested -powers up with ignition on and shuts off a couple seconds after ignition is turned off. Ill put the bumper cover back on tomorrow and test her out
Finished my install. Heres the pics on facebook.
http://www.facebook.com/album.php?ai...2&l=b17ee46fc0
I got it now
Removed Bumper Cover
This is whats under neath. Horn Must be relocated
Install Pump
Install Fitting
Install Hoses
Electrical
Nozzle and check valve. Used locktight
Install Pump
Install Fitting
Install Hoses
Electrical
Data Logged it this morning. Waiting to hear back from Vince on adjustments. It felt great above 15 lbs boost. I have it set at 10 and 20 but I think im going to set it to 15 full on.
its always been my favorite.
