DevilsOwn Alcohol Injection DevilsOwn Alcohol Injection is a Supporting Vendor of cobaltss.net
Contact: devilsown
New Outside mount nozzles
Old Jan 28, 2008 | 12:53 PM
devilsown's Avatar
Outside Mount Nozzles
DevilsOwn is committed to providing you the best nozzle you can buy. DevilsOwn nozzles consistently deliver superior, long-lasting, trouble-free performance. Each nozzle is tested individually on flow rate, spray angle, balance, and uniformity of spray. You can't find a better nozzle anywhere. The DVL-2700 features 1/8' npt threads on the outside of the nozzle so that it can be screwed in from the outside of your intake. With built-in O-rings, leaks are something that are only associated with our competitors. The removable screw-in 80 micron filter allows for easy cleaning, and the nozzles are nickel-plated to protect from methanol and increase their life.
The DVL-2700 nozzles disperse the alcohol/water mixture into the smallest droplets possible at any pressure above 40psi and produce a fog-like mist. They are small in size and weight and allow for maximum air flow into your intake without blocking it. DevilsOwn designed this nozzle unique with the orifice recessed, which when air passes over the nozzle a pressure drop is created on orifices. This dramatically improves atomization of the nozzle.
Old Feb 4, 2008 | 01:28 AM
devilsown's Avatar
Anyone have any questions about this.
All of our kits are now shipping with this new nozzle.
Old Feb 4, 2008 | 01:31 AM
M-Dub's Avatar
Can we order this nozzle.... and how does this work with an already installed nozzle? Like say can it be interchanged with my nozzle from Aquastealth?
Old Feb 4, 2008 | 10:34 AM
devilsown's Avatar
http://www.alcohol-injection.com/out...zzles-135.html
Yeap, you can order the nozzles off our site or threw any of our dealers.
These nozzles mount best into a bung.
I am not familiar with Aquastealth. And what they use.
Old Feb 22, 2008 | 03:33 AM
devilsown's Avatar
Few more sized now added. We offer more sizes of nozzle so you can finaly tune your engine than any other company period...
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
