Welcome to DevilsOwn Alcohol Injection [Supporting Vendor]
I'd like to welcome DevilsOwn Alcohol Injection to our community.
Check them out and see what they have to offer
http://www.alcohol-injection.com/
Welcome guys!
Welcome guys!
Raven SS thanks, my typing needs help
Lsjwannable I was in the process of making up a post for today. I had 4 orders over the weekend for you guys/girl who see this post i will refund the sale amount. Should see the price changed on our store shortly.
lol i was like wtf when i clicked on it then i clicked on the one up top and looked at the difference...im looking into a meth kit soon as hell because of my current situation with a blown engine..im really liking the trunk mounted kit that is offered by ais..i know u cant bash but what are some high points of ur kit?
Raven SS, Not trying to bash
Coolingmist makes a good kit, Tank design is a nice thought. I wish i would have came up with it.
What makes our kit Better Compatible parts...
Yellow metals will leave a powder that can cause clogged nozzles. This was the main reason we don't use bare brass fittings. Its not compatible. Snow performance the largest alcohol injection company does not use brass either. Why would us and snow say that bare brass is bad if it wasn't? Nickle coatings protect your investment and help to ensure a trouble free system.
Check valve
Some company's don't include a check valve or solenoid with the kit. You must purchases them seperatly. 2 piece design that can be user tore down, if a problem does ever arise. Others need to be Cut apart with a saw... Also has the push to connect built in.
Our electronics...
Smallest Progressive controller on the market. Pretty much 1/4 the size of our 2 of our competitors.
Our can be easily mounted to the dash with 2 sided tape. Other are 2 heavy, bulky for dash mounting. Wires directly to your stock map sensor. No vacuum/boost lines to run onto your dash. "who wants to run a vacuum/boost line to something thats mounted on there dash? Others are ideally located in the engine bay or trunk.
Status Led on the controller. Since ours is intended to be mounted on the dash you can monitor the led for system status. Cant see whats going on under the hood or trunk. And no need to drive around with a laptop in the pass seat.
No need for a laptop to adjust your kit. Or you just have to trust its worken..
Our electronics are done in a production environment. Some of the other guys circuit boards are hand solder. We don't have some poor guy standing in the corner soldering parts to the circuit board. Every controller is bench tested before it leaves our hands.
Best tech support around. We are avid car guys and know alcohol injection like the back of our hand. If we don't' know something we can find out for you. We can easily be reached by phone, email, and even our forum.
We run these exact same parts in our daily drivers and even run the same off the self parts in our 9.80s 508ci F2 Procharged cutlass shop car.
Oh, did i mention our lifetime warranty if you purchases our devilsown brew for the life of the product
Standard is 1 year. We stand behind what we sell.
Check valve
Our electronics...
Check valve
Our electronics...
Check valve
Our electronics...
Link to the Sale
Sales has started. No group buys here. Don't have to worry about someone else not following thru and the group buy stalling. This sale will be active till next tuesday.
Yes, we do put a lifetime warranty on parts as long as you use our devilsown brew. If you don't' use mix then its just a 1 year warranty on parts. We are able to do this because we use parts that are compatible with methanol.
Macgyver2484
Sep 2, 2015 05:44 PM
