2.4 SS vs. 2.0 w/o SC
its a odd question but. which car do u think would win if a 2.4 SS raced a 2.0 SS without the Supercharger. i think the 2.0 would still win. what do u think?
I would say the 2.4 When it comes to NA engines the larger CID would win. (most likely) The 2.0 is pushing 12 Lbs of boost for 205. The 2.4 makes what? 170HP. The 2.0 would be your typical honda without the S/C in other words = SLOW
whoever said the 2.0 would win is just silly. here's a more accurate scenario that has actually happened. the 1g eclipse came with 3 engines in 4 trims. gsx/gst had 4g63t, gs had 4g63 n/a, and rs had a 1.8(not sure of engine code). ok, my lancer ralliart gets beat up pretty bad by a gsx/gst. i have a 4g69 2.4 w/ mivec. (very comparable to the ss n/a) but if i race a gs eclipse, the eclipse get's MURDERED!!!!!!!!!! so there you go. w/o the supercharger, the ss 2.0 is a str8 up PILE OF ****!!!!! but who in there right mind would go n/a on that engine. hopefully nobody that is sane!
Originally Posted by SilverStreak
I'd wager the 2.0 makes less than 145 in the N/A trim...... that's what the 2.2 makes.
I can e-mail it to anyone who wants it.
Here's a pic from the PDF, since I don't know how to post it:
^ ^ ^ that "140 jumps to 200" comparison is the 2.2L (same block but stroked and a higher CR) there is absoluetly no way the 2.0 (with supercharger removed) would make 140. It has a compression ratio of 9.5:1 and less displacement. Nobody (excpet GM maybe) knows what a 2.0 - SC would make, i doubt it would even run properly given the fuel managment would have it running so rich. If you could get it to work i doubt it would even put out 100Hp.
Obviously that figure includes them running it with the ECU configured for a NA 2.0L!
That said, there is no way that adding 12.5 Psi of boost adds 105HP the engine? Think about what you are saying!?!?!?!?
Remeber that the 2.2L is tuned more for economy, while the 2.0L is tuned for performance. 140 HP is certainly possible out of 2.0L without the supercharger!
Originally Posted by celicacobalt
i thought as a rule of thumb that each psi would equal out to 10whp
I don't even know what to say...
Originally Posted by mi6_
I just checked. It makes 140HP without the Supercharger. I have it in a PDF pamphlet from gmpowertrain.com. The link on GM's site is not working. But it states that the 2.0L Supercharged made 140HP before the Supercharger is put on it.
I just sent you a privat message
Sep 28, 2015 12:51 PM
