Drag Racing Kindle Racing and Dalcorp Racing
Aeroforce Interceptor 1/4 mi accuracy
Old Sep 12, 2011 | 10:07 PM
ShagMeyer's Avatar
I just got my dual interceptors and wanted to try out the performance option. I know the speedo on the balt lags, so does this also cause the interceptor to lag?
Old Sep 12, 2011 | 10:22 PM
nizzle's Avatar
it's gonna be a lil off even if you speedo/speed senor and all that are perfect. If your speedo if a lil off due to tire wear, different sized tires setup, etc then it will be quite a bit off. I'll give mine as an example. I've done quite a few runs messin around with my areoforce. Time after time my aeroforce told me I was running anywhere from a 13.0 - 13.2, however when I went to the track I could not get under a 13.6. Then again, there are a lot of factors that factor in to the differences between those runs too.
Old Sep 12, 2011 | 10:42 PM
ShagMeyer's Avatar
I thought something was off, it said i ran a 13.85 and i was just taking it easy, trying out the 1/4 mi feature. Also said i had 5.5 0-60 which seemed quick for the way i took off.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
