Drag Racing Kindle Racing and Dalcorp Racing
Base LS Times
Old May 20, 2006 | 08:56 PM
biniecki's Avatar
Base LS Times
I went up to milan today with some guys and got a couple runs in. It was my first time ever running so my reation times need alot of work. My car has no mods except for a DC Sport Strut Bar. My first run i staged all the way up to the line. Here are the numbers. I dont have a scanner to scan the slips so ill just post what the numbers are.
Reaction
+.8279
60 Feet
2.6282
330 Feet
7.2189
1/8 Mile
10.974
1/8 Mile MPH
65.95
1000 Feet
14.1771
1000 Feet MPH
75.76
1/4 Mile
16.9270
1/4 Mile MPH
81.51
The second run i staged in the middle and the didnt really help my reaction times lol however i must have gotten on the trottle a bit more cuz i ended up with a better time. Here are those times.
Reaction
+.9048
60 Feet
2.5050
330 Feet
7.0531
1/8 Mile
10.761
1/8 Mile MPH
66.77
1000 Feet
13.9422
1000 Feet MPH
75.98
1/4 Mile
16.6773
1/4 Mile MPH
82.10
Old May 22, 2006 | 01:21 PM
tiny's Avatar
decent times for your first time
dont worry about reaction time, it doesnt affect your time AT ALL
you should work on the launch, you can tell bu the 60 foot. 2.2 is what you should shoot for. If you lower your tire pressure, it'll help
the fastest stock base coupe time is 15.6
Old May 22, 2006 | 06:31 PM
Clmbngfrk18's Avatar
not bad for you first time my first couple were in the mid 16's so far my best is a 15.8
trick to getting a good reaction is go one the 3rd yellow light it take that much time for you brain and body to react
Old May 23, 2006 | 06:03 PM
biniecki's Avatar
Any tips on how to launch? I cant brake torque it very much cuz it wants to break loose; same thing with the ebrake. Also for reference i have an automatic
Old May 23, 2006 | 06:18 PM
hmm an auto im not sure about i got a stick it took me a while to figure out how to launch that but what ive learned is start out like you would normal driving then ease into it im sure its way diff in an auto also are you putting it in 1 and shifting your self??
and for an auto im sure those are good times a stick will always be quicker unless you drive a super car
Old May 23, 2006 | 06:22 PM
D4u2s0t's Avatar
i konw in my 2006 lt, if i go WOT, it changes gears at redline... i would think that would be your best bet... if i don't hold the pedal down all the way, it changes gears before redline.
Old May 23, 2006 | 06:31 PM
biniecki's Avatar
Not sure what WOT is. Also I just leave it in D i dont do the manual shifting of an automatic. I use to have an auto stick and if i put it in that mode i could just floor it and it would shift at redline.
Old May 23, 2006 | 06:39 PM
Tomtwtwtw's Avatar
If you have an auto and are getting bogged down or t/c lights when launching, then it may help to drop the stick into the lower gear, as that should disable the t/c. A little bit of spin will probably help you off the line quicker, then as soon as you've got traction, bump it back to D.
Old May 23, 2006 | 06:46 PM
wot= Wide Open Throttle in other words foot on the floor
Old May 24, 2006 | 02:28 PM
biniecki's Avatar
The only way to get t/c off is to put the ebrake on or to put the car in L. If i did that then i would have to manually shift back to D.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
