Battery in trunk issues at track inspection?
Just wondering if anyone has had problems with the SS S/Cs and how the battery is mounted in the trunk? If I remember right, when I went to the track years ago with my buddy, he had a Integra with the battery mounted in the trunk, and they told him at tech inspection that in order for him to race he had to have a battery shutoff switch mounted to the outside of the car, because his battery was in the trunk.
I was just curious because I plan on going out to the track in a few weeks and don't want to have any issue with tech.
They shouldn't. It will depend on who inspected your car. In all honestly, most auto-x's I go to, the tech guys assume the fusebox in the front IS the battery, so they'll probably grab it, see if it's loose, and check you off.
If you run across someone who doesn't know anything about Cobalts, they might give you a hard time thinking you relocated it. I'd take along an owner's manual (I think it's in there, it should be, something about the location of the battery) to show that it comes in that location from the factory.
i went several times,and no issues at all...they asked me where the battery was and i told them it was factory mounted in the trunk..u arent goin to have problems at all...if you do,owners manual book as the description of the battery mounting place
ACTUALLY....I think if you log into MyGMLink you can get a PDF copy of the owner's manual.
Last edited by alleycat58; Apr 26, 2007 at 01:59 PM. Reason: Automerged Doublepost
This is correct. I have about 60-70 passes with my car. Never any probs with the battery in the back. Its stock like that so they can't deny you permission to race for that reason alone. Now if it was not at the stock location you would have probs.
https://www.mygmlink.com/main/US/en/...2k05cobalt.pdf
See if that link works. Page 5-39 in the section "Checking things under the hood" there's a subtitle for "Battery" it states it is located in the trunk.
If its stock they don't bother you. Look at wheels for example, if you run aftermarket wheels and hit faster then a 12.9 (if I remember right) then you need the studs to protrude thru the lug nut so the tech guys know the wheel won't come off. If you run stock wheels no such issue exists.
I can see the benefit of a rear wheel drive car to install the battery in the trunk. Maybe its time to relocate the Cobalt battery to the front for improved traction. Does that make any sense or am I having a blonde moment?
ive never had a problem, they check my fuse box and check it off. when i had my interior stripped he check my fused box signed it off then relised it was in the truck and ask is that aftermarket, i said no its stock and hes like well what did i wiggle up front? i said a fuse box and hes like well you can tell im old
It's done for a handling advantage for performance driving. The battery on the rear passenger side helps offset the weight of the driver and even out the crossweights.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
