Cobalt SS/TC vs Maxima
This details a battle between bitter rivals.
Cobalt SS vs Maxima on Youtube
The above video was a rematch after this terrible defeat.
Cobalt vs Maxima
Cobalt vs Maxima
good runs regardless of mph. Just goes to show ya that making a ton of HP isn't always the best setup. So many times people forget or skip tires.
but, throw those same tires on the cobalt and you don't really stand much of a chance.
The cobalt is making roughly 330whp, maxima weighs about 150-200lbs more and around 270whp N/A.
Oh and that cobalt can't use anything even remotely near the same tires.
15" wheels and slicks (big sidewalls, tons of options) fit on the maxima. The cobalt can't go below 17" wheels, and has very few options for real slicks.
mickey thompson does not make an et slick lol. is it the et street or et drag?
and on the size change: what were you launching at? do you think the car will hold a higher launch rpm?
This is an earlier defeat of the cobalt.
Cobalt vs Maxima
ET drag obviously.... When I said ET slicks, that means they aren't the street radials. lol
Clutch was slipping on the launch, but it can handle 5k clutch dumps pretty easily.
Cobalt vs Maxima
That is a picture of the cobalt driver caught red handed attempting to steal the NOS bottle.
Even if they are bias ply, I would not have called et streets a slick.
Switch would be for better gearing (especially on the launch) and so I can stay in 4th gear with higher power since I'll be pushing it close when I start spraying again (upwards of a 200 shot).
On the first run we were both using general exclaim UHP street tires. His are 235/40/18 and mine are 245/40/18. He still lost through the 1/8th!
Still thought, I wasn't tring to take anything away from you, impressive for a maxima.
Ditto on the MT ET drags or streets. They are both slicks.
Last edited by ralliartist; Jan 10, 2010 at 02:23 PM. Reason: Automerged Doublepost
Like I already said, stepping the tire up will make your gearing less aggressive. It may help your top end to prevent you from going to an overdrive gear or something, but it'll hurt your launch. Now if your spraying, that'll more than make up for the loss in gearing. It's all about tq on the holeshot. Nitrous will give you a nice be tq spike and rocket you on the launch. But the bigger tire will hurt.
In my case, I have very short gears. with the 24.5x8" slicks, I do not always hook (especially not on a shot of nitrous) and I will be topping out 3rd gear in the 1/8th at 92ish mph, 4th gear at around 118. I go to both 1/8 and 1/4 mile traps and I want it to be optimal for both. With a 125-150 shot of nitrous and some other N/A mods planned, I am hoping for 98-99mph traps in the 1/8th and 120-122mph traps in the 1/4, and with suspension and bigger slicks, I can spray out of the hole and pull a 1.6-1.7 (some other maximas have done 1.5s, but I don't think I will be able). The bigger tire will allow me more traction, longer gears so I can stay in 3rd in the 1/8 and 4th in the 1/4, faster '60 foots, and probably snapped axles.
That's a badass maxima. What all is done to get the 106-107.5 trap??? 350z intake manfold swap?
I sure do miss my 02 Maxima as it was a fun/nice car. I managed a 14.33 at 98.5mph with a K+N drop in.
The 6-speed (HLSD) that I have now is good up to about 500 wtq on slicks. If I have issues at higher power, I can swap in a 6th gen maxima 6-speed transmission with stronger synchros and a par gearset that should be good for upwards of 800wtq. If I break any axles, I will send them to driveshaft shop and have some strong ones made at a pretty steep cost, but it will be worth it to have solid parts.
Mods to get the 106-107.5 traps were these:
Autozone SRI
NWP spacers
Vias delete stock IM (no port matching)
Cattman v3 Headers + Y-Pipe with open dump
UTEC summer tuned to 6700 rpms. I forgot my laptop and couldn't tune!
3330LB race weight full interior
Current mods that you see in the early part of that video are:
3" CAI
Kinetix IM + NWP spacers and LIM port matching
Cattman v3 Headers + Y-pipe
2.5" mandrel Custom Maxima brand catback + extra resonator and test pipe delete.
UTEC tuned aggressively for the winter with more timing and 7200rpm rev limiter.
Slipping clutch failure.
I will unbolt the exhaust at the track as usual, with plans to use an electric cutout later on if a build progresses.
Going to swap in a stage 3 street clutch or a 6-puck ceramic clutch... not sure which yet.
Autozone SRI
NWP spacers
3" CAI
Nope. Here are some of my nitrous videos. I was untuned with just boltons and 75 shot. This was winter 08.
Group Run on youtube
maxima vs cobalt
maxima vs cobalt
Best ET on an almost empty bottle... that 1/8th mile with a full bottle could make for a 12.2-12.3
Best MPH
