Drag Racing Kindle Racing and Dalcorp Racing
Decent 2nd time at the track
Old Jun 18, 2006 | 05:28 PM
OneFast20's Avatar
Thumbs up Decent 2nd time at the track
so friday night i went out to quaker city raceway in salem and it was my 2nd time taking the cobalt out there. My fastest was a 14.9 @ 93 mph...i think the mph is slow because the track goes slightly uphill right at the end...but i atleast got into the 14's so i'm happy with it. I was getting 2.3 60' times all night, couldn't really get it any lower because of wheel hop...i was slipping the clutch at 2k but still ended up with wheel hop... heres some times...
R/T .830 .781 .768
60' 2.309 2.318 2.341
330 6.361 6.419 6.412
1/8 9.650 9.740 9.725
MPH 74.32 73.55 73.80
1000 12.433 12.555 12.523
1/4 14.921 15.070 15.018
MPH 93.65 92.68 93.48
this is how the runs went in order...15.3, 15.1, 14.9, 15.2, 15.0, 15.0, 16.0(spun 1st, bogged 2nd) any suggestions on how to get my times a little lower and more consistant let me hear them!!!
Old Jun 19, 2006 | 11:25 AM
korax123's Avatar
When I lived in Campbell, OH I ran my 04 Redline at quaker City. That track sucks and dows go uphill a little bit.
All I could run is 14.9@96mph all the time. I think you need to shift faster or just stay in 3rd gear at the end of the run.
Old Jun 20, 2006 | 05:39 PM
OneFast20's Avatar
ya i stayed in 3rd gear, and i have a short throw shifter so i think i shifted quick enough...i guess in 2 weeks stadium gm in salem will have my stage 2 and install it so hopefully low 14's here i come...
Old Jun 21, 2006 | 12:17 PM
SS4ME's Avatar
My suggestion. Stage vehicle, raise the rpms to about 1500-1800, release clutch. You will loose traction, the key is spinning the tires until they regain traction. Restrain the the urge to mash the pedal to the floor when you loose traction, you will regain it. Once you have the traction under control apply full throttle somewhat gradually. You will most likely loose traction once again at the top of 1st gear. Deal with the loose of traction, shift into 2nd, then into 3rd. The race should be over as you run 3rd gear out. This is how I ran a 14.3 and a 14.4! Good luck next time!
Old Jun 21, 2006 | 05:28 PM
SilverSS/SC's Avatar
....plus , if the air is as hot sticky and humid as it has been over here in Indiana , theres alot of your MPH . I was running 102-103 in the cool spring , now in this horrible air with a couple more mods I can barely break 100 .
Getting that 60 down a lil lower will get u some more ET , but all considered .....a 2.30 on stock tires as stock as you are on a crapfully prepped track is actually pretty respectable . I think youll be pleasently surprised racing on a track that doesnt go uphill too
Old Jun 21, 2006 | 05:35 PM
jester's Avatar
Hey im from Columbiana OH, right near boardman. Iv been to quaker a few times. Never actually raced but iv definately heard bad reviews about the conditions. Are you gona be at the Super nats this weekend?
Old Jun 21, 2006 | 06:04 PM
bad93ex's Avatar
Hmm that sucks that it goes uphill at the end of the track. Those are still some good times for being close to stock. You should check your DA to see if thst is affecting your times. It can sometimes add over a half second to your times.
Old Jun 22, 2006 | 11:20 AM
OneFast20's Avatar
hey jester...ya i was going to go out on sat. and run all day, then probably head back to boardman to cruise 224...are u going to be out there?
bad93ex what do u mean by check my DA?
Old Jun 22, 2006 | 05:20 PM
DA = density air . Which is actual air quality when all parameter are factored . For instance , a dragstrip I race pretty normally sits at 662 ft above sea level . There have been times when the actual air quality is equal to 3500 above sea level , and all the way down to negative 1000 feet . The only way to measure it is with some type of weather station , which can be pricey . But theres also small hand held ones that are pretty affordable .
Old Jul 1, 2006 | 02:10 PM
jester's Avatar
Sry I couldnt make it. It was my girlfriends Grad party. But wish I could have. I heard there were a couple of guys out there. Oh and on the seventh im gonna be pretty bored so im gonna go to boardman and see what I can stir up that night round 10 or 11.
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
roth
Sep 26, 2015 12:16 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
