Drag Racing Kindle Racing and Dalcorp Racing
does anyone know how to launch, and shift rpms?
Old Sep 24, 2006 | 08:52 PM
bavoose's Avatar
i was just curious because i went to the track today and the best i got was 15.8 in 1/4 mile can someone tell me what i am doing wrong because i launched at like 2000 to 3000 rpms do i have to launch later and what is a good rpm to shift at thanks.
Old Sep 24, 2006 | 09:02 PM
IROC R/T's Avatar
That's the supercharged Cobalt? Heck I seen a non supercharged run 16.0! Post your time slip or at least tell us all that numbers from it. What was you 60'?
Old Sep 24, 2006 | 09:11 PM
Asphalt Assault's Avatar
LOL well I guessing you have a 3 second launch or something. Are you stock?
lauching at 3000 to 2000 rpm. now way man you will sit and spin. I launch at 1100 and ease it out of the whole. it looks funny like your driving no better than granny, but really smooth and slow is sometimes faster. you want to launch as hard as you can with out much wheel spin. if you get wheel hop you want to back off not go harder. I have had the horrible launch and I got 15.5 once. 14.7 was my best stock but you could do better than that I think.
hope that helps some.
other setup tips. - Burn out to remove rocks and dust from tires, also air down tires to 24lbs.
good luck
Old Oct 11, 2006 | 04:53 PM
Robin1's Avatar
i have a similar problem. i was racing my SS/SC cobalt with a K&N cai, and the best i got was 15.4 and that was double clutching after 2nd. couldn't get the launch right.
Old Oct 11, 2006 | 04:58 PM
StinkBOMB's Avatar
2000 is the most you want to launch on stock tires. Don't dump the clutch either. Let it out fast but smooth my first time was absolutely dreadful too. Just don't get too excited. I was super stoked about being at the track and I lost my mind so my launches sucked. A good RPM to **** at is red line. You're going to need all 6500 of those RPMs you get with a stock limiter, and if you're modified, all the way to around 7000 rpms.
Old Oct 11, 2006 | 04:59 PM
D4u2s0t's Avatar
takes lots of practice.. these cars are hard to launch, untill you get used to it...
Old Oct 12, 2006 | 09:51 PM
what kind of times do you post with this method?
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
2009blackSS
Sep 30, 2015 05:57 PM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
