Drag Tires
axles snap because of wheel hop. The harder the tire, the easier and more likely you are to wheel hop. Street tires are the worst, drag radials wheel hop if you don't launch right, and slicks don't wheel hop at all if you aren't an idiot. The widest you can fit without having to grind anything whatsoever is 9.5" wide slicks. if you go to a 10.5" like me, you'll have to grind on the suspension mount. The key is to get a SOFT compound with a decent amount of sidewall and a wide contact patch. 16" rims with a tire no taller than 26" tall and 9.5" wide is your best bet.
I'll be due to break one, I know. But I've only launched real hard on my slicks like 3 times. Every other time I've only launched at like 3K rpms or below.
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
