Drag Racing Kindle Racing and Dalcorp Racing
Finally got to the track
Old Jun 9, 2007 | 11:13 AM
shawns94's Avatar
I went out to the track last night and got in a few runs. My best run was a
60'....2.288
330....6.188
1/8....9.365
mph....76.64
1000....12.134
1/4....14.463
mph....97.03
The car wasn't getting good mph it seemed to flatten out at the top end of the track. I think it is because of my stock exhuast. Any pointers would be appreciated thanks.
Old Jun 9, 2007 | 11:26 AM
Mercury's Avatar
That is a really bad time for all the mods you have.
What RPM are you shifting at?
Old Jun 9, 2007 | 11:44 AM
-Jayson-'s Avatar
yeah sounds like you need some serious driving mods. You should be trapping around 104+MPH with those mods and running mid to high 13s all day.
Old Jun 9, 2007 | 12:52 PM
arng22's Avatar
god damn are u shifting at or about 7K or are u shifting at 4? thats friggen strange
Old Jun 9, 2007 | 01:29 PM
lsjwannabe's Avatar
what is the elevation
Old Jun 9, 2007 | 04:53 PM
shawns94's Avatar
not sure the elevation. I live in kansas so it shouldn't be real high. My clutch was slipping going into 2nd for about 2 seconds. wouldn't even scratch second, it sounded kinda like an automatic transmission. And like I said my top end was really flat.
Old Jun 9, 2007 | 05:03 PM
DaREDss's Avatar
stock balts trap that high sometimes
and maybe your car is pulling timing because your running a 2.79 on the stage 2 tune and 42 injectors
Old Jun 9, 2007 | 05:05 PM
AROON02's Avatar
My Stock Run Slowest Was 14.8 Your Going 14.4? Thats Terrible Driver Mod Is A Must , Def Get Exhaust But Also I Shift At About 65-6700 Every Time. Also Dont Shift By Sight Shift By Sound, Dont Be Scared Or Nervous, Try And Break The Car, You Wont But Thatll Get You Lower Times. Mines A Lease, I Beat The **** Outta My Car
Old Jun 9, 2007 | 05:14 PM
shawns94's Avatar
Lets assume that I am not a horrible driver (I know where to shift and how to launch Thank you) What else could be causing the problem? I was thinking the same thing as DAREDSS. Anything else would be helpful.
Old Jun 9, 2007 | 05:22 PM
DaREDss's Avatar
Its not drver you had a 2.2 60' so if you got launching basically down thn im prett sure you know how to shift to third gear. I think its what I said before the stage 2 tune is crapy as it is and you have a 2.79 so its back it down. Just get it tuned and im sure it will run a lot better
oh and your clutch slipped that ***** you up a lot too
Old Jun 9, 2007 | 05:32 PM
shawns94's Avatar
so some 60# injectors, tune and exhuast should get it running good again.
Old Jun 9, 2007 | 08:56 PM
DaREDss's Avatar
if you go up to a 2.85 I think it will run a lot better
Old Jun 9, 2007 | 10:34 PM
shawns94's Avatar
Thanks for all your help man
Old Jun 9, 2007 | 10:37 PM
poppagun's Avatar
ya get a 2.8 that will help you a lot the 2.7 is two small for stage 2 tune and 45 injectors
Old Jun 11, 2007 | 10:42 PM
shawns94's Avatar
Another question. I put the dual pass kit on the week before I went. I am still putting dexcool in it to fill it up and get all the air pockets out. Would that have made a huge difference. Maybe the intercooler wasn't cooling my IAT's properly. The excess heat would probibly reduce power alot right?
Old Jun 11, 2007 | 11:11 PM
SSdan's Avatar
Willing to bet the heat + stage 2 tune with the 2.8 = timing pull.
Old Jun 11, 2007 | 11:22 PM
shawns94's Avatar
thanks
Old Jun 11, 2007 | 11:23 PM
light'bolt's Avatar
42's and 2.8 pulley, injectors are 100% @ 6200 rpms
I think, can't remember where I read that at
Old Jun 12, 2007 | 12:05 AM
shawns94's Avatar
nice to know. That is why I ordered my 60#s today. Thanks
Old Jun 12, 2007 | 11:00 AM
SSdan's Avatar
Yea they max out up top. I shift at 6k now, I can literally feel it pull timing up top.
Old Jun 12, 2007 | 11:10 AM
R&C_rallySS's Avatar
Next time you go and you have all your bugs worked out with a 2.2 60foot your going to be running mid 13s easy. Maybe better, good luck man.
Old Jun 12, 2007 | 04:49 PM
shawns94's Avatar
That is what I am hoping for.
Old Jun 15, 2007 | 07:31 PM
CynicX's Avatar
Sounds like the car is going to be pulling timing...hence the good launch with not so good trap. Keep in mind a car will retard timing to prevent it from destroying itself....
Would be curious to see the AFR if those injectors supposedly max IDC around 6200 RPM. Something tells me its probably a pretty scary number for the stock internals...
Old Jun 15, 2007 | 09:44 PM
shawns94's Avatar
Well I am glad I got the info before it was to late. Hopefully Everything will come together in a couple weeks or so.
Old Jun 16, 2007 | 10:57 AM
-Jayson-'s Avatar
if you didnt put more dexacool back into the cooling system and bleed out the air bubbles, chances are your intercooler wasnt working for ****. Im suprised your engine didnt blow up
