Finally got to the track
I went out to the track last night and got in a few runs. My best run was a
60'....2.288
330....6.188
1/8....9.365
mph....76.64
1000....12.134
1/4....14.463
mph....97.03
The car wasn't getting good mph it seemed to flatten out at the top end of the track. I think it is because of my stock exhuast. Any pointers would be appreciated thanks.
60'....2.288
330....6.188
1/8....9.365
mph....76.64
1000....12.134
1/4....14.463
mph....97.03
not sure the elevation. I live in kansas so it shouldn't be real high. My clutch was slipping going into 2nd for about 2 seconds. wouldn't even scratch second, it sounded kinda like an automatic transmission. And like I said my top end was really flat.
stock balts trap that high sometimes
and maybe your car is pulling timing because your running a 2.79 on the stage 2 tune and 42 injectors
My Stock Run Slowest Was 14.8 Your Going 14.4? Thats Terrible Driver Mod Is A Must , Def Get Exhaust But Also I Shift At About 65-6700 Every Time. Also Dont Shift By Sight Shift By Sound, Dont Be Scared Or Nervous, Try And Break The Car, You Wont But Thatll Get You Lower Times. Mines A Lease, I Beat The **** Outta My Car
Lets assume that I am not a horrible driver (I know where to shift and how to launch Thank you) What else could be causing the problem? I was thinking the same thing as DAREDSS. Anything else would be helpful.
Its not drver you had a 2.2 60' so if you got launching basically down thn im prett sure you know how to shift to third gear. I think its what I said before the stage 2 tune is crapy as it is and you have a 2.79 so its back it down. Just get it tuned and im sure it will run a lot better
oh and your clutch slipped that ***** you up a lot too
Another question. I put the dual pass kit on the week before I went. I am still putting dexcool in it to fill it up and get all the air pockets out. Would that have made a huge difference. Maybe the intercooler wasn't cooling my IAT's properly. The excess heat would probibly reduce power alot right?
Sounds like the car is going to be pulling timing...hence the good launch with not so good trap. Keep in mind a car will retard timing to prevent it from destroying itself....
Would be curious to see the AFR if those injectors supposedly max IDC around 6200 RPM. Something tells me its probably a pretty scary number for the stock internals...
