Drag Racing Kindle Racing and Dalcorp Racing
finally went to the track
Old Oct 22, 2011 | 07:29 PM
xodus's Avatar
Went to palm beach international finally after being tuned for probably close to a year ended up getting 4 runs in
The track prep was bad this night, would chirp shifting to second, then would spin once the turbo spooled up,no one was getting the greatest traction even the skyline guys were complaing they could only cut a 1.8 60 instead of 1.5
A little disappointed but a driver mod would help.
First run was a 13.8 at 107.3 with a 2.2 60 missed 3rd ...solo run
this run i shifted into 4th other 3 runs stayed in 3rd.
next run was a 13.7 at 106.4 with a 2.33 60 against a speed3 new one 15.4 at 94 with i/e/t
next run was 13.7 at 107.7 with a 2.3 60 against a turbo 240 14.7 at 107
last run 13.7 at 107.8 with a 2.3 60 against a tundra 13.4 at 105
The car has terms 24psi tune, zzp dp, zzp intake tube, treadstone tr8 intercooler, injen hotside pipe, K/N drop in filter.
Tires are nitto neogens at 26 psi
launch was around 2-3k
Any suggestions?
Old Jan 1, 2012 | 01:15 PM
xodus's Avatar
Went back a couple weeks later i was able to pull out a 13.5 at 107.7 with a 2.24 60'
Old Jan 1, 2012 | 01:18 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Those 60s are killing you
Old Jan 1, 2012 | 01:23 PM
Dart_SI's Avatar
Get some mounts they'll help a lot. I reccomend Powell stage 2 or Ottp stage2
Old Jan 1, 2012 | 01:35 PM
TurboTechRacing's Avatar
Yeah the 60 foot time is killing you. Should be able to pick up almost another .3-.4... Another set of mount options are:
NEW! Turbo Tech Racing STOP Transmission Mounts Chevrolet Cobalt 2005-10 (F35 Trans) ON-SALE! - Turbo Tech Racing, LLC
Turbo Tech Racing Solid Upper Engine Mount Chevy Cobalt/Redline/HHR 2.0/2.2/2.4L Manual Trans - Turbo Tech Racing, LLC
Old Jan 1, 2012 | 01:38 PM
xodus's Avatar
I have the stage 1 mounts, and also the football mod,added twm cable clamp and bushings also,which wont help just feels better,and working on getting the 60' down. only tracked it a few times. But i do have DR now , so next time i go out which is friday ill use those so well see what happens.
Old Jan 1, 2012 | 02:00 PM
Cobalt_Daddy's Avatar
that's one quick tundra haha
Old Jan 1, 2012 | 02:02 PM
I was thinking the same, what did the 5.7L have done to it?
Old Jan 1, 2012 | 02:08 PM
nhanson's Avatar
Could be a single cab short box...less weight.
60s are killing ya
Old Jan 1, 2012 | 02:16 PM
RooTBeeR's Avatar
in for the dr times
Old Jan 1, 2012 | 03:55 PM
xodus's Avatar
no clue what was done but it was moving... and ill post times for you after the dr /football mod
Old Jan 6, 2012 | 11:36 PM
nRRe's Avatar
sub'd
Old Jan 6, 2012 | 11:48 PM
Killswitch's Avatar
2008 Toyota Tundra TRD Supercharged - First Test - Motor Trend
thats my guess
Old Jan 7, 2012 | 02:26 AM
RooTBeeR's Avatar
500hp/550tq...interesting
Old Jan 12, 2012 | 02:14 PM
AARON-SS-TC's Avatar
im getting the similar tune to you, and cant wait for the track on it. tires and mounts are always what helps out fron drive cars with good pwer.
trap speed is pretty good, im sure with better driving and mounts, 12.9-13.2 is in your future...gl
Old Jan 12, 2012 | 02:29 PM
ItalianJoe1's Avatar
Those tundra's run 14's stock, it was probably lightly modded if anything. 104 trap isn't much, he was getting off the line nicely. I was running 13.5's at 104ish with the Z with a 2.0 60 foot, at stock power. Those tundras have a lot of gear, a nice 6 speed auto, and 370ish hp stock.
Old Jan 12, 2012 | 08:02 PM
xodus's Avatar
didnt get a chance to go that day, ecu ended up getting bricked when i had got sent the wrong tune. will update in like 2 weeks when i get to the next test and tune.
Old Jan 26, 2012 | 09:23 PM
Billy Baldone's Avatar
Even with a 2.2 60' your mph with those mods should be 110 or so.Are you powershifting?(NLS) for you youngsters.Trifecta tune only I drove my dad's Cobalt 13.2 @ 107 with a 2.18 60'.My car same day with DP and intake wnt 12.9@111.You should be where I was at.
Old Jan 26, 2012 | 11:15 PM
xodus's Avatar
nope no nls for me.
actually making it back tomorrow to the track after the new tune goes in.
not every car is going to trap the same either,
depends on what your elevation and da is also, im sure your air is better than mine.
Old Jan 29, 2012 | 03:27 PM
Florida air is humid and nasty, believe me, i know cause i live here..lol
gl and reach for that 12.9
BTW, what rpms are you shifting at and what gear are you ending in?
I launch @ 2500, then I shift 1-2 @ 5800, then 2-3 @ 6k, then 3-4 @ 6200, ending in 4th obviously, and about 75ft before finish.
Old Jan 29, 2012 | 04:54 PM
You should raise the rev limit and carry 3rd through the traps, will get you quicker. Kills you to shift right before the line.
Old Jan 29, 2012 | 08:04 PM
really?
i'll try it
Old Jan 29, 2012 | 10:34 PM
really?
i'll try it
Yeah, time spent shifting is time not putting down power. Better to go a couple hundred rpms past the peak than have to stop sending power to the wheels.
Old Jan 29, 2012 | 10:38 PM
09BlueBaltSS's Avatar
Trap is a little low. What were the 1/8 mile times?
Old Jan 30, 2012 | 09:41 PM
xodus's Avatar
1/8 if i remember was 8.9 8.8 something like that, i dont have the slips near me.
