Drag Racing Kindle Racing and Dalcorp Racing
First time with the SS
Old Jun 16, 2010 | 07:28 PM
Defining's Avatar
Last night I took my Cobalt (2010 SS/TC) down the 1/4 mile for the first time. I ran a best of 14.187 @103.11. I had a 2.35 60' time. My car is stock as a rock with 2950 miles on the clock. I was really happy!! I'm hoping to run 13s with out actually spending any money .
Old Jun 16, 2010 | 07:31 PM
skip_jones's Avatar
that's a good time.
Old Jun 16, 2010 | 07:32 PM
Adam84's Avatar
Very nice runs you work on those 60fts and you will have 13's no problem. Best I got out of mine stock was 14.4 at 102 with a 2.3 60ft. I baby the car out of the hole though.
Old Jun 16, 2010 | 07:49 PM
SS4ME's Avatar
You'll get 13s with more track time. Avoid hot days.
Old Jun 16, 2010 | 07:54 PM
myfakeevo's Avatar
damn. i ran that with my stock sc.
Old Jun 16, 2010 | 07:55 PM
Defining's Avatar
Thanks ! My first run I bogged off the line and ran a 2.68 60' haha. Then I got the hang of it and launched around 3,000 rpms while quickly slipped the clutch. I hooked pretty good but still spun a little. I was running 34psi. I figure if I air down to maybe 28psi or so and try the footballs I might be able to run a 13.9.
Old Jun 16, 2010 | 08:00 PM
Adam84's Avatar
Really good time for a sc. You must have been launching hard out of the hole, I was just leaving at idle. Car only had 1200 miles on it first time at track.
Old Jun 16, 2010 | 08:05 PM
SS4ME's Avatar
A 2.1 60' which is most certainly attainable without footballs and you're running a 13.9 or better. Try launching at a slightly lower rpm.
I ran a 14.2 stock. You are babying that thing which is fine. It's your car.
Old Jun 16, 2010 | 08:18 PM
Defining's Avatar
Try launching at a lower rpm?? Ok--thanks! I'll try launching around 2500rpms with lower tire pressure.
I was crossing the line right at the top of third. Are other people shifted into fourth or staying in third?
How come I'm only able to run 1/10th a second better then the SC guys who have less hp??
Old Jun 16, 2010 | 08:53 PM
Shibito's Avatar
They have instant boost, it's easier for them to control the power going down in 1st gear. It's really all in the first gear. You're walking a stock LSJ from then on.
Old Jun 16, 2010 | 10:27 PM
terry11's Avatar
Tire Pressure = 20 or less is you want some good 60's
At least for me. As the night goes on if your running bracket or elimination it will get cooler and your tire pressure will drop even more. I ended the night one time at like 10 psi but i was hooking like a ****. Hurts top end a little tho
Old Jun 17, 2010 | 07:15 AM
SS4ME's Avatar
Yes. Less tire-spin=better 60'. So try 2500 rpm because it should be easier to control your tires.
Also a stock LSJ is underrated. They dyno higher than 205 in most cases. Either way the best stock times for the LSJ is 14.0 where the LNF has gone as fast as 13.5 stock.
Old Jun 17, 2010 | 11:43 AM
scopedmp5's Avatar
gay.....really
seriously gay......
or learn how to drive...hint hint
Old Jun 17, 2010 | 11:56 AM
SS4ME's Avatar
Originally Posted by scopedmp5
seriously gay......
Learn how not to be a dick!
Old Jun 17, 2010 | 12:59 PM
Staged07SS's Avatar
Administrator
Administrator
OP: Good run for your first time !! That is about the average time for a stock SS/TC.
scopedmp5: Nice 1st post. Try not being a tool .... hint hint
Old Jun 17, 2010 | 01:04 PM
1badBlueberrySC's Avatar
I pulled a 13.99 at 102 on mine bone stock....
Old Jun 17, 2010 | 06:50 PM
Defining's Avatar
Thanks for the advice guys!! I'll hit 13s before long ! I'm hoping to run again when I don't have to wait in line for so long. My engine temp was ~200 and my intake temp was in the mid 80s.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
