Drag Racing Kindle Racing and Dalcorp Racing
first time at the strip!
Old Aug 10, 2011 | 11:19 PM
dumpleRL's Avatar
I just got back from the track and although i had a blast, I NEED MORE SPEED or a clutch or to learn how to drive... heres some vids
I had wheel spin like a beast
r/t .557
60 2.374
1/4 15.310
trap 93.09
r/t .621
60 2.324
1/4 15.217
trap 94.28
any tips suggestions pointers are sweet
Old Aug 10, 2011 | 11:24 PM
LS6Rally's Avatar
Learn how to STAGE!
anyways, id probably feather the clutch out around 2500 instead of about 3-3500. and it sounds like the 2-3 shift was a little off.
what are you running for tires, and what are your mods?
my best in my 2.4 is 14.9 @94.2
Old Aug 10, 2011 | 11:28 PM
dumpleRL's Avatar
the really long stage was the cars that went before something messed up on, but i have a 2.9, header and full 3 inch dp and cat back, 60s and a tune
tires.... nankang ns1 :sadface:
Old Aug 11, 2011 | 10:48 AM
beast10007's Avatar
just go to the track a few more time you will do better....if you work on the 60 you car can run 14's easy.
try 22psi in the fronts
Old Aug 11, 2011 | 02:15 PM
Erick161's Avatar
almost sounded like you tried to powershift or no-lift-shift into 3rd? The key is practice. Lower the pressures up front like stated, go from a lower rpm and feather the throttle/clutch until you feel traction.
Old Aug 11, 2011 | 03:16 PM
dumpleRL's Avatar
yes i was power shifting because i forgot to setup the wotbox and ill try the better launch method what.do lsjs with my mod usually run
Old Aug 11, 2011 | 03:33 PM
jonathan923's Avatar
what mods do you have?
Old Aug 11, 2011 | 03:51 PM
RooTBeeR's Avatar
lewk up
Old Aug 11, 2011 | 09:18 PM
Erick161's Avatar
My buddy has a WOT box, and honestly, its more nuisance than anything. It doesnt provide the LSJ any gains IMO?\... Its "launch control" just holds RPM and dumps the clutch, it doesnt actually use traction control...since we dont have that. And theres no point in NLS on an LSJ. Just my 2 cents.
Old Aug 11, 2011 | 10:46 PM
LS6Rally's Avatar
i wouldn't go too low, i like 26-28psi up front . and run 50 in the back.
^ and i agree with Erick, NLS in an LSJ isnt needed.
Old Aug 11, 2011 | 10:49 PM
startingline05's Avatar
i can prove that NLS is needed on some lsj cobalts
Old Aug 11, 2011 | 10:51 PM
beast10007's Avatar
I run 22psi when I use street tires can cut 2.1-2.0 60's all day
Old Aug 11, 2011 | 10:54 PM
Erick161's Avatar
Tires are key. What are yours?
I mean, an LSJ-T maybe, but you cannot seriously say any blown LSJ would benefit. I mean, please, prove me wrong. Im all about learning..
Old Aug 11, 2011 | 11:01 PM
LS6Rally's Avatar
does the car feel unstable or a little wobbly at the top end of the track? i tried 22 and 24 and didnt like it, 28 seems to be my sweet spot. i make about half your HP and i cut 2.2's
Old Aug 11, 2011 | 11:05 PM
beast10007's Avatar
[QUOTE=Erick161;5972307]Tires are key. What are yours?
I have 555's
Old Aug 11, 2011 | 11:06 PM
BlueStang's Avatar
With some more practice you'll do better, and at least you did it on the track and not the street.
Old Aug 11, 2011 | 11:08 PM
beast10007's Avatar
yes they are a LITTLE wobbly around the 1000ft mark but it is not bad I have traped 116.2 with street tires.
My slicks wobbly a LOT more.
In drag racing the first 60ft is almost the whole race so yea a better 60ft with a slower ET is mostly faster then a shitty 60ft and a good ET
Old Aug 11, 2011 | 11:14 PM
LS6Rally's Avatar
^ i know that the 60 is the most important, i just dont like feeling like im driving through a hurricane. every car is different, im also running 17's with 225/45's so i have a bigger sidewall than most anyone whos running 18's
Old Aug 11, 2011 | 11:27 PM
beast10007's Avatar
haha i understand I use your rims with my slicks
Old Aug 12, 2011 | 11:44 AM
you got me there, i was just going to say it benifits a turbo lsj. but it really does make a great difference for a turbo car when you no lift shift. it really can cut about half a second off your 1/4 mile time because you dont have to wait for the turbo to spool again after you shift.
on a blown lsj yes it is really pointless, but the launch control does help alittle
Old Aug 12, 2011 | 07:42 PM
dumpleRL's Avatar
tires are my down fall
Old Aug 12, 2011 | 10:54 PM
Erick161's Avatar
its not true launch control unless it uses traction control...thats really the point of launch control. So, because LSJs dont have that, IMO, its rather pointless.
IIRC, isnt it just in the ECU? (the traction control function).
Yeah, turbo car, completely see the benefit.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
