Drag Racing Kindle Racing and Dalcorp Racing
GM STAGE 2 track numbers
Old Sep 10, 2006 | 02:52 PM
  #51
IROC R/T's Avatar
hey guy's you are right- tuning an NHRA car is very important for them that is why they use their own correction formula's to stay consistant. At this stage of the game I don't see where you really can tune much of anything on a 13-14 second cobalt? So the DA really has no affect on anything you do right? other than to make your 1/4 mile times seem better than they really are?( I don't mean this as a cut but most street car guy's seem to use these correction numbers to make their ET look better than use them for tuning purposes) I have a handheld DA calculator but to tell the truth on my turbo car it's not really much use. I even went as far as to make my own correction factor specifically for my car with the info I have logged with the last 200 runs but not much consistancy was achieved other than the 25 % seemed to be as close as all my figuring.
Altitude yes- anybody that travels for bracket racing has to deal with this.
"There are so many things that contribute to an ET that its almost impossible to compare times at different tracks sometimes. I totally agree.
Using a correction factor on your ET without saying what your real ET on a forum like this is BS though and I don't mean to offend anyone either though.
Old Sep 10, 2006 | 02:59 PM
  #52
IROC R/T's Avatar
Also wanted to point out for those that don't understand- if your car is set up to build 15PSI of boost it does not care what the ouside air pressure is it will still build the same 15 pounds of boost wether or not the ouside air pressure is high or low- thus creating it's own atmosphere. On an NA engine the air is just sucked in as it is.
Old Sep 10, 2006 | 03:00 PM
  #53
an0malous's Avatar
ahhhh i see your point. i wholeheartedly agree.
I moreso use the correction thing when i see someone at a primo sealevel track in my own mind.
like if i see someone run a 14.0 with just stage2, i think to myself that at my local tracks, if i were to pull a 14.4 or so its probably fairly similar.
but if i had a 14.4 run its still a 14.4 run. posting it as a 14.0 would be definate rice
Although posting it as a 14.4 and then putting in brackets (14.0 DA corrected) would be fair i guess.
Old Sep 10, 2006 | 03:14 PM
  #54
IROC R/T's Avatar
"but if i had a 14.4 run its still a 14.4 run. posting it as a 14.0 would be definate rice"
That's the way I look at it too. And if you post the real ET along with the corrected one the reader can decide for himself on how much weight to give the corrected time.
Old Sep 10, 2006 | 07:53 PM
  #55
Asphalt Assault's Avatar
Originally Posted by Julex
Did you shift really slow? Cause stock I have same time with a worse 60 ft... Not to be an ass just wondering, cause 14.2 with stage 2 and a 2.1 sounds like you didn't go as fast as you could have.
I can shift fast. You have misread the info. in my signature. I got a 14.2 with a 2.3 60ft. My best 60ft was screwed up cause of the shifter The car had issues that day. The shift knob!! piece of crap came right off. misshifted second and after recovering I managed to cut my hand and get a 14.5.
I think I can get 14.0 or 13.9 but now I will gun for 13.8.
EDIT - I have only done 12 runs with the car ever. 6 stock and 6 S2. 4 runs have been screwed by the shift knob. I dont have enough seat time. and sometimes they make us run out of the groove. running at a prepped track is so different from the street. The car needs 245/45R17's I am looking at NITTO 555 R's
Old Sep 10, 2006 | 11:19 PM
  #56
repoman's Avatar
Stage 2, Air Box Mod, Magnaflow exhaust
Race 1:
R/T: 1.217
60': 2.498
330: 6.592
1/8: 9.774
MPH: 76.56
1/4: 14.836
MPH: 97.38
Race 2:
R/T: .636
60': 2.529
330: 7.029
1/8: 10.39
MPH: 74.73
1/4: 15.450
MPH: 97.01
This is my very first time to run the car. I just had the S2 installed Friday. The humdity at the track was very high and the track conditions sucked ass as well. The biggest problem I had was the F**king clutch slipping like a 2 dollar *****. So I guess my next mod will be a clutch that can actually hold the power that is already there.
Old Sep 10, 2006 | 11:41 PM
  #57
hatrickstu's Avatar
Race 1:
R/T: 1.217
60': 2.498
330: 6.592
1/8: 9.774
MPH: 76.56
1/4: 14.836
MPH: 97.38
Race 2:
R/T: .636
60': 2.529
330: 7.029
1/8: 10.39
MPH: 74.73
1/4: 15.450
MPH: 97.01
sorry to have to sound like a douche, but it seems the only thing wrong with this car is the driver. not trying to be mean, im sure you will improve a bunch with practice, but a 2.49 and a 2.52 60 foot kinda speak for themselves. i myself have around 50 passes at the strip with my stock clutch, probably 25 passes with stage 2 and dont have clutch slippage unless i am hotlapping it (knock on wood), which i dont. seems to me the people that drive these cars dont like to let them cool down or just plain abuse them, thus clutch failure.
Old Sep 10, 2006 | 11:47 PM
  #58
repoman's Avatar
The car has 7k on it. I didn't get on the car until it had about 1500 on it. I had to wait about a hour and half before the runs because a guy wrecked his bike. Coming out of 1st into 2nd both times I just feathered the gas and it still slipped. I wasn't planning on any hard runs since this was the first time at the track. It's plain and simple the clutch in MY car won't hold what its got now. Oh yeah and a guy with a WRX was only getting 1.9 to 2.1 60 foot time. The track wasn't hooking at all.
Old Sep 28, 2006 | 08:23 PM
  #59
Speeed's Avatar
Originally Posted by mi6_
Your numbers are good! But, correcting for air density or altitude is not ricer math, but an exact science.
Hi everyone! New member here, no cobalt though, just an srt-4
Anyhow, this post really inspired me to sign up for your forums.
A car with forced induction isn't affected by an increase in altitude NEARLY as much as a naturally aspirated vehicle is.
Here is my example. LS1 Camaro's ran 15.0-16.0 @ 87-96mph, last night at bandimere.
In my SRT-4 I ran a 14.030 @ 99.87 mph.
So lets see. . .
Bandimere is at 5800 feet
We will use this calculator
http://www.greatlakesdragaway.com/co...onfactors.html
Lets say it was. . . 45 degrees that night (it was more like 60) and about 20% humidity (more like 30%)
And we will pretend the Atmospheric pressure was 30.5 in. HG (It wasn't, it was more like 29.5)
That gives me a density altitude of -1500 feet. So we subtract that from 5800 feet and arrive at 4300 feet, so lets just apply these "Exact science" correction figures to my time!
13.287 @ 105.49 mph.
In a bone stock SRT-4. . . ok sure. If you used the actual conditions to figure correction I ran a 13 flat at 107. . . .
Sorry, DA correction does NOT work with forced induction cars. The fastest stock SRT time at sea-level or anywhere else for that matter is only 13.7 I believe. So I must be the next Michael Schumacher!!!!
Oh wait, DA corrections are BS on a F/I car.
Class is adjurned
Old Sep 29, 2006 | 08:30 AM
  #60
IROC R/T's Avatar
So lets see. . .
Class is adjurned
I joined the forum to point out the same thing. The DA correction factor is misued so often it makes me sick. I think many of the people new to drag racing pick up on others doing it to make their times look better and unknowingly are giving false times as they just don't know any better. The magazines do the same thing and this really pisses me off. Did you guy's know the times listed in motortrend and car and driver are corrected times? the ones that are quoted as gospel? They won't tell you what correction factors they use but they do say they use them. Do they use the same factor on foreced induction cars as they do NA cars? Remember the issue when they compared the SRT-4 and Cobalt SS? They had the 1/4 mile times about equal- I think both at about 14.4 in the high 90's but the SRT had a 0-100 listed at like 14.1? The next issue they tried explaining how they used corrected times to compare the two cars but from the info it sounds like they incorrectly used the NA correction factor on the SRT by factoring in a more +DA to the SRT's ET.
Old Sep 29, 2006 | 08:34 AM
  #61
CTCOBALTSSS's Avatar
Good numbers bro, very good numbers. Nice job!
Old Sep 30, 2006 | 02:28 AM
  #62
trust me with the ingalls or different mounts the car will be much quicker out of the hole, a 2.268 is not a great 60 foot man, 2.1's and 2.0's are what can be considered good on these cars on street tires.
I did 2.18 no traction mods. and I think it can be done better.
Old Sep 30, 2006 | 02:34 AM
  #63
so you still think horsepower is the way to go?
With my testing with GMS2,with and without BWoodies traction bars, I dont think HP or Traction mods are worthy of lowering my times substatially. Bigger better tires are worthy. will reduce wheel hope, and I will be able to launch harder to lower times.
Old Nov 27, 2006 | 01:23 PM
  #64
chevysalesman614's Avatar
good times guys! sorry to hear about your elevation and air density problems
Old Nov 29, 2006 | 04:12 PM
  #65
R&C_rallySS's Avatar
well those numbers helped me out in guesstimating my 1/4 time. good times, i am also running stage 2, with the ingalls though. however i only have a 1000 foot track here, i ran 11.54 in the 1000 so im thinking i would have run about 13.6-13.7 depending on your trap.
dude your car could easily be running 13.5's if you got that 60 foot down, remember these cars make plenty of power, they have a hard time getting it to the ground, invest in traction mods!!!
I could not agree more. I ran 14.2 @ 100mph consistantly stock. With intake and ingalls I'm hoping for a 138-14 flat. With Stage II I'm hoping for 13.6-13.7s. Good luck keep up the hard work.
Old Nov 29, 2006 | 09:59 PM
  #66
Julex's Avatar
??? ummm you expect .2-.4 seconds off 1/4 mile from just intake and tq dampener? I would LOVE to see you prove this haha think of it this way losing 100#s takes about .1 off your time, I doubt intake and tq dampeneer will increase your velocity that much.... Unless by intake you mean a mini turbo :P
Old Nov 30, 2006 | 12:50 AM
  #67
Tofu's Avatar
I could see .2 tenths from the ingalls easy...if it drops his 60ft by a tenth. My control arm bushings netted me consistant 2.0 60fts and a couple 1.9 60fts on stock rubber.
Old Nov 30, 2006 | 09:01 AM
  #68
Can I see your time slip? I am not a doubter. I am just trying to learn off your times and compare to my slip. I did 11.74 in a 1000'. If I could do the 11.54 I believe a 13.7 is possible. not sure you could pull out a 13.5 though but I am willing to try.
thanks!
Old Nov 30, 2006 | 09:13 AM
  #69
Follow up. I tried BWoody bars. this is what I learned. They work well! they do get rid of wheel hop. the problem with wheel hop is the control arms to the frame. bushings are to flexy (control arm deflection - technical name).
what I also learned is wheel hop is when your tires are breaking traction. to get a good 60ft. you need to push the car to that limit. getting a traction mod does not improve your chance of getting a better 60ft. as I said already I got 2.18 60' on stock tires with no traction mods.
So what do we do? increase HP? no, that will only help after 60 or 70 ft.
we need more traction, which equals tires. get bigger or wider tires and stickier tires and also suspension setup would help with weight transfer.
Old Nov 30, 2006 | 09:43 AM
  #70
207GT04's Avatar
Good to read everything. sounds like a little bit of release of air outta the front two tires and just easing outta first and peeling out just to the point in which wheel hop should happen with out actually hopping. should result in some decent 60' times. all im hoping for is a nice sunny day without rain here in florida on sunday and prayin to break 13s wouldnt be all that bad either. running the stage 2 and an injen intake. updates soon....
Old Nov 30, 2006 | 09:58 AM
  #71
I was in Orlando just this November. Man it is nice there and warmer. Would like to move there one day! Good luck with the runs and speed shift that thing.
Old Nov 30, 2006 | 10:05 AM
  #72
johnkb8's Avatar
my buddy on this site ran a...
13.2 w/ mods
gm stage 2 w/ 2.7
header w/ downpipe
airbox mod
front strut bar
and!! some hoosier drags of course
but...
i running 14.2 almost stock w/ just intake @ 100mph
wonder what i could do with stage 2 installed
Old Nov 30, 2006 | 12:35 PM
  #73
13.2 w/ mods
gm stage 2 w/ 2.7
header w/ downpipe
airbox mod
front strut bar
but...
That helps me with getting an Idea of what I could do with my planned mods. What was size was his hoosier's and do you know his 60's?
Old Nov 30, 2006 | 12:53 PM
  #74
johnkb8's Avatar
60ft was only 2.0.....might of had 1.9 but dont think soo
all i know is the tires are HUGE!!! they just fit in wheel well w/ the 17 or 16 inch wheels he got for them
Old Nov 30, 2006 | 12:57 PM
  #75
johnkb8's Avatar
"R33P3R007" <---screename here
