Drag Racing Kindle Racing and Dalcorp Racing
Having trouble with 1-2 shift
Old Jul 25, 2009 | 04:17 PM
Darcy's Avatar
Went to the track last pulled a best time of 13.7 @ 102 (90 degrees out). However on most of runs i either missed the 1-2 shift or it went in but seemed really clunky. Is this just me screwing up or is the clutch in trouble already? Any suggestions on improving this shift would be great.
Old Jul 25, 2009 | 05:24 PM
06cobalt racer's Avatar
does it go in fine during normal driving? under the front 2 cupholders the cables snap into a holder for them. check there and see if they poped out. i am pretty sure thats where it is.
Old Aug 4, 2009 | 03:26 AM
HeavyRightFoot's Avatar
I have the same problem with the 1-2 shift under power.
Figured it was just me.
Old Aug 4, 2009 | 03:29 AM
bigbuzzum's Avatar
me 2, it's a bitch when in high rpms
Old Aug 4, 2009 | 03:30 AM
EatonTVS07's Avatar
might be the roll pin
Old Sep 18, 2009 | 11:20 PM
aterminatorz's Avatar
Are you sure you put the clutch all the way to the floor before moving the lever? Also do not let up on the clutch until the lever is done moving to the next gear.
Old Sep 19, 2009 | 12:01 AM
cmiller8006's Avatar
Dont rev the car to 6000 in first shift at 5500 out of first. Dont try no lift unless you are not spinning, even the slightest bit, it will not go into the next gear.
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
The Rookie24
Sep 20, 2015 04:33 PM
roadrunner132
Sep 19, 2015 04:35 PM
