Drag Racing Kindle Racing and Dalcorp Racing
Huge fail incoming
Old May 18, 2012 | 06:43 PM
donkeyballs's Avatar
Originally Posted by BlackLsCoupe
recall on what?
Ignition lock cylinder
Old May 18, 2012 | 06:45 PM
ford's Avatar
Hey on street tires I was able to run 12.19 at 132 lol.
You make a lot more power than I do as well lol.
Old May 18, 2012 | 06:47 PM
ford's Avatar
Originally Posted by donkeyballs
My car is running at the dealership CAUSE THE PIECE OF **** WON'T TURN OFF!!
Sounds like there is no excuse not to drive to the track...
Old May 18, 2012 | 06:51 PM
Perfect.disguise's Avatar
Don't have them here with me, but the fastest quarter of 11.05 was a 7.30 1/8th mile
What is the mph looking like?
Old May 18, 2012 | 06:55 PM
Sonicyeller's Avatar
Just FYI guys, the ignition cylinder recall will fix your problems forever. The part installed is a different tumbler/cylinder design completely and eliminates the cause of the key sticking in ignition issue. I did my recall the day after it came out from GM.
Old May 18, 2012 | 08:21 PM
cmiller8006's Avatar
102. Have trapped 106 so far.
Old May 18, 2012 | 08:23 PM
Yea. What kind of boost you pushing now?
Old May 18, 2012 | 08:32 PM
Cobalt_Daddy's Avatar
lol i went into the dealership and told them my ignition was sticking (lies) and had it fixed before it even became a problem
Old May 18, 2012 | 10:54 PM
ford's Avatar
Gonna try a pass on 24psi but track has been shut down since I arrived.
Old May 18, 2012 | 11:55 PM
ford's Avatar
Hmm this is pathetic. Made 2 passes and my traps are lower than stock turbo. Trapping 113 in 1/4 and 90 in the 1/8.... I figured more on the big end but i dunno.
Launching is certainly different on this setup. I need some seat time on the build but so far it sucks even thouhh the car feels strong on the street
Old May 19, 2012 | 12:53 AM
  #36
Are you using NLS?
Old May 19, 2012 | 01:00 AM
  #37
srt-10's Avatar
yea thats pretty slow. I was trapping 109mph when i had my balt with the TVS, making 287hp.
Old May 19, 2012 | 09:24 AM
  #38
ford's Avatar
Are you using NLS?
No. I am being a bit conservative on the stock transmission with the Exedy hyper single attached to it. The way it engages will blow something up.
I know i trapped higher than this on stock turbo.
Here are my thoughts:
#1: I need to learn to drive the big turbo setup. I out 60' a modded WRX and because the car just searches for 7400 (still havent done my valve springs) i only sit in 1st for as long as i feel comfortable. On my shift to 2nd the car falls out of power and i give up like 4-5 cars on the WRX yet i walk him down in 3rd and put another 5 cars on him (he trapped 107).
I have some trouble pedaling the car through 1st and 2nd as i get a weird stutter/flutter when i start half throttle or on/off throttle. Don't know if it's something with the BOV or the manual boost control, but it's a huge issue for me as well. If i can't walk it out it makes my life hard. I also see flutter/surge at low RPMs, and low RPMS low boost only (like under 3psi).
I know what people will say about my shifting earlier and being not aggressive but I wasnt trying to go for broke last night. I know a few mph are left in the car from my end.
#2: I need to datalog and spend time with the car. Before the trip to the track i literally have about 15-20 minutes driving the setup. It seems to pull hard on the street, i mean it feels like the engine wants to pull itself from the front of the car and keep on going.
However, butt dynos lie. I do know it rips the tires like it never has before, even with 19psi in the tires. My stock turbo could not destroy the tires the way this does.
Time will tell, we all know the turbo is capable of a lot more so ill just have to get the car and myself dialed in. Driving this is nothing like the stock K04, and i need to remember that.
Old May 19, 2012 | 12:56 PM
  #39
He'l it's a completely different way of driving. You can actually leave at like 4000 rpm's in first and ride the clutch. At least with my car you can. It won't really spin till like 5k and up in first. Just have to practice. My first run on street tires was a 13.1 with a trap of like 124 same boost that I trapped 132 on street tires the same day and notched away at a 12.19. I know I make more power but that just shows what it takes to drive a big turbo car good.
Old May 19, 2012 | 03:13 PM
  #40
redcobalt07's Avatar
Have you ever driven on a track before?
Old May 19, 2012 | 06:12 PM
  #41
ford's Avatar
I agree. First run I bogged leaving I normally do. I found 4k was a great launch and murdered the wrx on that launch. When I get the springs in I will spin it higher and let it spin more if I have to. I was worried about the stock springs. Falling out of boost was killing me and I'm pretty sure I can't nls on a manual boisterous controller.
Those things and figuring out my half throttle issues will allow me to apply a little more skill into the mix. It sucks not being able to pedal the car
Yes lol more than 95% of this forum. Read above that I was slower thN on stock turbo.
Old May 20, 2012 | 12:23 AM
  #42
I think some of that half throttle issue comes from the mbc.
Old May 20, 2012 | 10:58 AM
  #43
ford's Avatar
Those are my thoughts as well, not sure what I can do to fix it though.
Old May 20, 2012 | 12:26 PM
  #44
Not to sure. But mine is the same way tho. Just the nature of using a mbc I think. I have just got used to it.
Old May 20, 2012 | 01:33 PM
  #45
ford's Avatar
Well i can solve the problem by getting some real tire on it and not needing to be on/off throttle so much
Iceberg
Sep 29, 2015 12:33 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
jrocstar
Sep 26, 2015 11:42 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
