Drag Racing Kindle Racing and Dalcorp Racing
Launching with Harrop TVS?????????
Old May 30, 2009 | 11:41 PM
Rodimus_Prime's Avatar
Ok so I'm pretty damn frustrated with this. I cannot find the right amount of boost and the proper RPM to launch at. Below is everything I have
Engine:
* Harrop 1320LSJ Supercharger 80MM pulley
* LS4 77mm Throttle Body
* Rebel Auto Worx LS4 Throttle Body Adapter plate with 1/8NPT tap for water injection nozzle
* Quaife Limited Slip Differential
* GM Performance Parts Dual Pass Option B kit
* HP Tuners Tuning Software
* OTTP Rotated Mounts
* Fujita F5 Intake
* CX Racing Heat Exchanger
* ZZP Midlength Header Ceramic Coated
* ZZP 304 Stainless 3 inch downpipe with Magnaflow High Flow Cat
* ZZP 3inch Whisper Catback Exhaust System
* AEM Water Methanol Injection Kit
* Siemens 660cc Injectors
I cannot for the life of me get it right. I either shoot into boost and then bounce off the limiter because it blows through the rpms too fast or it bogs because theres not enough boost or not enough rpm.
whats a good percentage and rpm to run, or at least something to start at nothing Im doing is working
Old May 30, 2009 | 11:43 PM
MP Cobalt's Avatar
What happens at around 3.5k to 4k?
Old May 30, 2009 | 11:46 PM
lsjwannabe's Avatar
avoid the water box when on street tires, drop tire pressure to a happy medium, leave off idle and gently roll into throttle. You have limited boost no?
Old May 30, 2009 | 11:48 PM
slowswap's Avatar
3.5-4k should be a good RPM with a little bit of clutch slippage.
Old May 30, 2009 | 11:50 PM
MP Cobalt's Avatar
Yeah if so just let off the throttle till you catch grip then ease it through 1st and hammer 2nd
yea right now the boost cut is kinda funky because of the LS4, I have zero boost to 4000rpm so its not all jerky and then the boost ramps in to 100% by 5500 or so
Yesterday I tried a 4000 rpm launch, nice tire spin with no wheel hop the rotated mounts are doing what they are supposed to and it really jumps through the rpms as soon as the boost hits so its hard not to hit the rev limiter in first
Old May 30, 2009 | 11:51 PM
slowswap's Avatar
Slip the clutch some.
Old May 30, 2009 | 11:53 PM
so let it out slower rather than dumping it?
Old May 30, 2009 | 11:54 PM
MP Cobalt's Avatar
yeah, or feather the gas until u catch a decent grip instead of spinning into your boost areas
Old May 30, 2009 | 11:58 PM
slowswap's Avatar
Dumping the clutch is never the fastest way off the line.
Old May 31, 2009 | 12:00 AM
Darkmanx's Avatar
i have no problems launching my **** , maybe you need some good tires. i have no boost cut and i also dont have a ls4 tb
Old May 31, 2009 | 12:02 AM
BLAZIN07SS's Avatar
I'm too JDM for you
2,000 rpm. street tires at 24psi. slip the clutch out of the hole. got me a 2.1 60 foot on stock tires
Old May 31, 2009 | 12:03 AM
With the LS4 its very hard to have a smooth and gradual engagement of anything in 1st gear. I have some somewhat worn stock contis on my 08-09 SS wheels if that means anything. They do grip way better than the redline 17s with brand new 225/45 Yokahoma S-Drives, I spin the **** out of those.
Old May 31, 2009 | 12:07 AM
mmcgee123's Avatar
get some dr's or slicks im selling some bfg dr's 225-45-17 for 200 almost brandnew
Old May 31, 2009 | 12:10 AM
realllllllly how much shipped to 17111?
Old May 31, 2009 | 09:41 AM
Maxim_X's Avatar
You can't dump the clutch. If you have no boost until 4k then you should be able to hold the revs at 4 k, slip the clutch till the car catches up till about 4k then WOT. By then you will probably be leaving the 60' area and tire spin isn't a huge issue. I ALWAYS spin 1st a the track but it doesn't spot me from 60footing or launching well. I also find that if first is spinning ride it out of the rev limit for a second so that when you shift to second you don't bog.
Old May 31, 2009 | 09:46 AM
slowswap's Avatar
Most FWD drag racers will tell you a very little bit of spin helps get the car moving.
Old May 31, 2009 | 09:48 AM
victoryss's Avatar
heres me last night on STREET tires out launching an a4 ls1
https://www.cobaltss.net/forums/war-stories-54/few-suprising-races-tonight-173574/
more practice muh friend
Old May 31, 2009 | 10:16 AM
thats impressive
Old May 31, 2009 | 10:19 AM
victoryss's Avatar
thats impressive
bring R's to 2K let clutch out until it engages a TINY bit then go 1/2 to 3/4 throttle(depending on conditions) while slipping the clutch by 2.5-3K you should be WOT tires sticking....
Old May 31, 2009 | 07:12 PM
ralliartist's Avatar
go buy some real tires. Trying to launch hard on street tires is just dumb. and pointless.
SmitBag
Sep 7, 2016 08:05 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Josh@ottp
Sep 8, 2015 10:18 AM
lsjunior
Sep 4, 2015 10:23 PM
