Drag Racing Kindle Racing and Dalcorp Racing
Launching in second?
Old Jan 6, 2013 | 12:50 AM
ive heard that 1st is so low, it roasts the stock clutch on lnfs lol
Old Jan 6, 2013 | 02:43 AM
terry11's Avatar
It works fine on the street i've done it 3 times. Once on the 50 trim and twice with the 57mm turbonetics. 7k rev limit tap if off limiter about ten times side-step it a bit and smoke the tires to 80. What's all the fuss about? lol
Old Jan 6, 2013 | 05:19 PM
armcclure's Avatar
That's why that Trans/clutch is still in your car, right?
Old Jan 6, 2013 | 06:00 PM
Powell Race Parts's Avatar
terry11 is auto now? this thread is retarded.
Old Jan 6, 2013 | 10:55 PM
terry11's Avatar
It was always out of frustration because of trans issues to be completely honest haha
Yes sir. Just waiting on the trans controller and harness right now from Powertrain control solutions. It should be here in about 2 weeks
Old Jan 7, 2013 | 09:03 AM
Cobe's Avatar
I'd love to try it cause I was thinking it too. My car is put up for the winter or I would give it a shot with the new go pro.. and first thru second for me... **** man.. first just egnites the tires and i immedietly slam second then when second hits they break loose again and i feather the gas untill traction is caught again quickly and try not to slip the tires loose again.. but then nls into third at around 6600.... freight train mode(:
Old Jan 7, 2013 | 12:34 PM
05RallyYellowSS's Avatar
Originally Posted by Sonicyeller
I like to launch in reverse, way better ratio than 1st.
This......
I had a tranny shop swap 1st and reverse so now I get way better launches.
Old Jan 7, 2013 | 12:47 PM
vahdyx's Avatar
Originally Posted by 05RallyYellowSS
This......
I don't know if I believe you....
Sarcasm perhaps
Old Jan 7, 2013 | 02:38 PM
EXsoccer1921's Avatar
well there goes this thread...
Old Jan 8, 2013 | 05:36 PM
armcclure's Avatar
Old Jan 8, 2013 | 11:29 PM
  #36
Sarcasm perhaps
Yeah man, 1st & rev swap is not possible. Was just adding to the noise.
My bad..
Old Feb 26, 2013 | 07:32 PM
  #37
1BADSS/SC's Avatar
I read that it's best to launch a high HP FWD car in second gear is better than starting in first. Is this true?
If so is there any strain on say clutch, trans, etc. I'm assuming yes but to what extent?
Lastly is it a technique worth mastering or should I just get used to launching in first
you dont drive an aerial atom so dont bother trying to launch in second
Old Feb 26, 2013 | 07:33 PM
  #38
1BADSS/SC's Avatar
This......
Old Feb 26, 2013 | 07:35 PM
  #39
1BADSS/SC's Avatar
so let me get this straight....
youve done it a total 3 times with two different turbos..... I take it the second turbo is a little more durable than the first? Hmmmm.....
Old Mar 23, 2013 | 01:55 AM
  #40
terry11's Avatar
Now that I think about it probably launched in 2nd on that 57mm 4 or 5 times.
Just did this the other night with the auto swap. It was completely by accident but I let it go at about ten pounds and smoked the tires to 80. Half way through i realized my car never shifted and it just did that in 2nd gear. I was throughly impressed
Old Mar 23, 2013 | 03:13 AM
  #41
vahdyx's Avatar
I actually read that there's a way to get the most out of a launch from first to second gear. What I read was it's best to shift early rather than just launching in second. Basically what it said was based on HP and car, it's probably better to launch a car in first and shift earlier rather than waiting until red line.
So say in my situation it'll be better to launch and then shift into second say at 4k RPMs.
I don't know how to launch so it doesn't matter.
Old Mar 23, 2013 | 07:54 AM
  #42
^^^^troof.
Old Mar 23, 2013 | 01:08 PM
  #43
1BADSS/SC's Avatar
yes this makes sense and is much better for the tranny than launching in second
Old Mar 23, 2013 | 01:16 PM
  #44
cranemaster's Avatar
I can't do 1st to second in my car worth ****. The ratios seem so far apart.
Old Mar 23, 2013 | 02:37 PM
  #45
redcobalt07's Avatar
Get slicks. That will solve a lot of your problems.
Old Mar 23, 2013 | 07:09 PM
  #46
vahdyx's Avatar
Then axels and perhaps tranny depending on clutch
Old Mar 23, 2013 | 07:26 PM
  #47
your axles and trans will prefer slicks over street tires or a drag radial. the clutch, not so much.
Old Mar 23, 2013 | 07:40 PM
  #48
This thread is entertaining.
Old Mar 23, 2013 | 10:50 PM
  #49
vahdyx's Avatar
I see. I'm just under the impression that slicks and drag radials snap axels and if you have a KY Clutch (stage 3) or something as strong it can ruin trans. Much like launching I have no expertise on the subject.
I only have 3rd hand experience. I don't know the whole story either, but 2 Colorado LNFs broke their axels at the track using these tires.
Old Mar 23, 2013 | 11:00 PM
  #50
its how you launch. You cant sidestep the clutch on a balt. u gotta work the clutch.
