Drag Racing Kindle Racing and Dalcorp Racing
Locked Up a Race for Next Track Season Thoughts?
Old Dec 26, 2011 | 11:03 AM
ULWizSS's Avatar
So i locked up a race for next season for a little cash. Its against a 02 Z06 with intake and exhaust. I would assume it would run in the 11.5 range if not a tad lower.
This is my setup:Might not have the head on for the race but everything else below is on it.
06 SS/SC G85 LSD Turbo Swapped
BorgWarner EFR 6758 Turbo
BYT HP Tuned
BYT 304SS Tubular Manifold w/ Merge Collector
BYT 304SS Catless Down Pipe
BYT 3' CAI
BYT "Stealth" Charge Pipes
TTR Intake Manifold
TTR Upper Engine Mount
TTR Rear Sway Bar
ZZP Front/Rear Transmission Mounts
ZZP Front Strut Bar
ZZP Stage 2 Race Trans 4.45 Final Drive
ZZP Stage 3 Axles
ZZP Stage 2 Port and Polished Head, ZZP Stage 2 Race Cams.
Mototron 80# Injectors
Boost Reference Fuel Pressure System Option 2
Eibach Front Sway Bar
Hallman Pro RX Manual Boost Controller
Exedy Stage 3 Hypersingle Clutch
DevilsOwn Progressive Meth Kit
N2MB Wotbox NLS/2Step
AEM Uego/Boost/EGT
Aeroforce Intercepter Scan Gauge
Hurst STS
HP Tuners Software
15's Verde Protocols Rims
15's M & H Slicks (Track)
18's Falken Azenis RT-615k(Street)
Thoughts everyone on the outcome?
Old Dec 26, 2011 | 11:25 AM
srt-10's Avatar
what hp are you expecting? If you can get off the line u might be close to him but i dont think you will take him.
Old Dec 26, 2011 | 11:26 AM
ULWizSS's Avatar
Should be sitting around 400-450 and i will be on slicks as well. Is the 02 z06 not a 12.5 car stock?
Old Dec 26, 2011 | 11:27 AM
Dart_SI's Avatar
Id suggest going the chain and football mod for traction. It all depends on your launch if Youl take him it not. If u can launch even with him or basically as long as he's not outlaunching u like crazy it should be cake.
Old Dec 26, 2011 | 11:34 AM
ULWizSS's Avatar
Yeah have only been on the slicks a few times but also on the M62 setup. Was launching at 4k and hooking realling hard with no tire spin and pulling 1.9. Would expect 1.7 to 1.8 with a little higher launch.
Old Dec 26, 2011 | 12:01 PM
donkeyballs's Avatar
If he is telling the truth about his mods you will win if you can drive your car with all the extra power you have but slicks will help a ton. If he is running H/C he will destroy you lol..
Old Dec 26, 2011 | 12:12 PM
cole3883's Avatar
if you pull ATLEAST another 1.9 id say you would get him. i want a video though haha
ohh and is he gonna be on slicks? hopefully he spins
Old Dec 26, 2011 | 12:15 PM
Dart_SI's Avatar
Z06's are fast but a c5 z06 with intake and exhaust only isn't far from a stock one.
Old Dec 26, 2011 | 12:35 PM
Exactly but if he has head/cam thats a whole different beast lol. If he's on slicks he could be cutting 1.4 60fts if he can drive so good luck getting him out of the hole
Old Dec 26, 2011 | 01:15 PM
ULWizSS's Avatar
i would love to have the head on before this race happens. I am sure i will.
Will also have a few passes down the track on her before i run the vette. Need to see where it sits here once its tuned by nick with meth.
Going up in a few days to get going on this.
Old Dec 26, 2011 | 05:40 PM
ULWizSS's Avatar
Guess we will have to wait and see. Will have a few track passes on the new setup before we run. So i guess time will tell.
Old Dec 26, 2011 | 05:42 PM
Projekt's Avatar
Not knocking your mods at all...but its sad that a c5 z06 can run faster then a cobalt with those mods.
Not knocking you like i side, simpling say...LSX's are impressive as ****.
Makes you hate a cobalt sometimes
Old Dec 26, 2011 | 08:08 PM
ULWizSS's Avatar
i have seen at least 10 of these in different years running no better than a 11.2 at the track, average I saw is 11.5 in the last 2 years.
I would certaintly hope my car would run with it on the stock motor and my boost turned up. Currently on 6psi on the EFR and need about 20 more psi.
I have a fully built head sitting downstairs just waiting to go on. This will be put on in Feb and before the race. It will be retuned again by nick and will be ready for a few track passes. Then its on for the race. There will be plenty of people filming from all angles and i will shoot from my gopro from my hood. We are locking it down for around 500-1k.
Also have the 80's, boost reference system, MBC to go on here with nick in a few days. Hopefully we can get meth running as well but might end up with just a 93 tune with the boost up.
Old Dec 27, 2011 | 08:24 PM
ULWizSS's Avatar
Anyone else want to put in their two cents?
Old Dec 28, 2011 | 04:18 PM
ULWizSS's Avatar
Guess not
Old Dec 29, 2011 | 10:51 PM
noorj's Avatar
If your sure that the z06 only has intake+exhaust then you you should take it, at best I think it could run very high 11's. But if he has the confidence to throw 1g down on a race I would think he isn't that stupid. He could easily have a strong heads+small cam combo, which you wouldnt be able to tell, but then run 10's. I guess it's up to your judge of character as to if hes lying about his setup or not. If he isn't lying I definitely think you have him. But either way, best of luck!
biniecki
Oct 25, 2015 02:23 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Extremespeed
Sep 29, 2015 04:34 AM
