Drag Racing Kindle Racing and Dalcorp Racing
opinions please. WTF? am I doing wrong?
Old Sep 1, 2010 | 11:49 PM
msonia03's Avatar
my mods.
Performance:
42# injectors
2.9 Smoothflow Pully/Hub
Ebay CAI
zzp ceramic header 1.75 primaries
zzp 3' dp magnaflow high flow cat
3' full exhaust
N1 Exhaust
Cobra Heat exchanger + Stock Heat Exchanger
Genuine Saab Aluminum Bushings
Genuine Saab Short Throw Shifter
GMPP Stage Clutch
NGKbkr7E Plugs, One Step Colder
Ingalls TQ Damper
Power Stop Slotted & Drilled Rotors
Tenzo R Springs
Tooned By 1Badblueberrysc with the help from MGM
Launch at 2400, tires at 21psi, these runs felt good, way good. no hop, no spin. why am I slow????? im on the right every run, # 192
Old Sep 1, 2010 | 11:51 PM
sundevil07's Avatar
is you ic pump working? your car has NO guts
BlackARCA06's Avatar
wanna race my 2.2 i think I might get ya. jk hope someone tunes in and helps you.
Old Sep 1, 2010 | 11:52 PM
LS6Rally's Avatar
your 60's are horrible! sorry bud. thats what my timeslips from my SS/NA look like.
21 PSI is too low for radial street tires. i would run about 26-28. other than that i dont know. a little wheel spin out of the hole may help, get the wheel speed up. also what is your elevation? i see your in colorado.
remember, if you lose time in your 60 foot, you cant make that back up, it will just domino down the track. you can always slow down, but you cant make it go any faster than it already is.
Old Sep 1, 2010 | 11:56 PM
OntarioKev's Avatar
Two questions, what are other cars running/trapping at your drag strip (other cobalts, newer mustangs, etc.)
You don't mention a wideband gauge in your mods, or an interceptor. What are your a/f and IAT2s?
if you don't know your A/F, that can have a big affect on power, and same for your IAT2s, if your IC pump is dead, your not going to make much power.
Kevin
Old Sep 1, 2010 | 11:57 PM
sundevil07's Avatar
a 2.2 60 is not bad at all on street tires, who cares about his e.t. his traps give away the fact he isnt making dick for power
Old Sep 1, 2010 | 11:58 PM
Phyrric's Avatar
Thats what my SS/SC stock runs here in hot as dicks FL on a shitty track, bumping for a savior
Old Sep 2, 2010 | 12:06 AM
msonia03's Avatar
I think the track is 5280. its right outside of denver.
I dont have a wideband, I have a narrowband, which dosnt help, says im running rich, but when my tuner looked over my tune he said im only running a lil rich, no biggy.
When I run 24psi tires and a lil higher I get severe hop. Tonight felt great, no hop at all.
I have no idea about my ic pump, is there a way to check it?
I know im at 100% on these 42's, but does that matter?
Ive made over 40 passes this season on this set up and its the same result.
on the street it rips, ive taken some faster 1/4 cars on rolls.
Im lost. I hate it. I should be in the mid 14's atleast. these 60 foots are killing me.
Old Sep 2, 2010 | 12:07 AM
Phyrric's Avatar
You should be in the 13's easily, stock stg2 balts have broken in 13s
Old Sep 2, 2010 | 12:13 AM
sundevil07's Avatar
check the t bottle in front of the blower and see if the water is moving in there, if not your pump is dead. your 60 foots are not killing you, i ran a 2.3 60 in my car and went 14.4 at 100 your car is just not making power. the altitude sucks but you are f/i so you should only lose a couple mph at the traps. 92 mph is unacceptable
Old Sep 2, 2010 | 12:17 AM
BlueBalt1113's Avatar
yea dude no hate but im running a 2.2 60time in my ls with intake exhaust and header
Old Sep 2, 2010 | 12:20 AM
msonia03's Avatar
where can I purchase a good ic pump
Old Sep 2, 2010 | 12:21 AM
LS6Rally's Avatar
well altitude will make a difference, but theres deff more to it. like i said my SS/NA is about 15.3 at 94 MPH.
Old Sep 2, 2010 | 12:22 AM
sundevil07's Avatar
Bosch Electric Intercooler Pump 317GPH 12V 0392022002: eBay Motors (item 140442993017 end time Sep-19-10 05:51:52 PDT)
Old Sep 2, 2010 | 12:24 AM
chris88z24's Avatar
For starters, put the stock intake back on and get a 3" pulley. The injectors are probably going static and the car is pulling a SHITLOAD of timing.
That 3" exhaust really is overkill with the mods you have. I bet it's KILLING your exhaust's velocity.
Old Sep 2, 2010 | 12:37 AM
msonia03's Avatar
I honestly have never seen the fluid moving thru the T. And i fill it up pretty frequently, but never see any leaks or puddles, i have no idea where the fluid goes.
Old Sep 2, 2010 | 08:04 AM
ralliartist's Avatar
HE IS RACING IN COLORADO AT ALMOST 6,000FEET!
Jesus ******* christ, what is so hard to see here. Your problem is your elevation. You are making about all you can at the elevation you are at.
Take a trip down to Topeka or KC and run 13's all day long. Make a short vacation out of it.
Old Sep 2, 2010 | 08:29 AM
trey ss's Avatar
bigger injectors, smaller exhaust, good tune
Old Sep 2, 2010 | 08:50 AM
^definitely not the problem.
There is absolutely NOTHING wrong with his exhaust, in fact, it's perfect for a supercharged car.
His tune sounds like it should be great if the people he claims tuned him did in fact tune him.
He does need bigger injectors, but that's not what's causing his slower than normal times.
Old Sep 2, 2010 | 09:31 AM
msonia03's Avatar
Ralli, you really think thats the best im gonna get out of her up here. I have a friend whos balt I installed the stage 2 on, pretty much same mods as me, except exhaust, clutch, and my tune. And she can run 14.7's all day.
I thought it was just my driving, which I know has alot to do with it, but I feel as if ive found the sweet spot launch now, the 60 foot arent reflecting that, but it feels awesome.
And matt did my tune, I logged it and sent them to him a lil over a month ago and he said my tunes fine, just need to jump to 60#s.
Im ordering the new ic pump today, that makes a lot of sense to me, never seen the fluid flowing thru the T. And since im running both stock and cobra wouldnt my pump kinda be working a lil overtime to push it thru?
Old Sep 2, 2010 | 05:00 PM
cmiller8006's Avatar
I would blame alot of it on the elevation your at, however blowers and turbos stuff the air in so its not as huge a difference of N/A. Your still picking up 20-22 hp on the big end so your making power, unless your tune is messed up in the first and second gear range. Your 60 isnt bad like some have said but its not good either, could use some work. Seems like you should still be trapping more at least.
Old Sep 2, 2010 | 05:07 PM
What track did you run at, what day and time. I just poked in one colorado track at 8 pm yesterday and the DA was 8600, now that can be signifigant.
Old Sep 2, 2010 | 05:37 PM
msonia03's Avatar
It was yesterday 9/1 between 4pm and 7 pm At Banidmere Speedway
Old Sep 2, 2010 | 05:42 PM
importkiller's Avatar
Yeah my best time at Bandimere was a 14.078 and my 60 was 2.4. It is the altitude for one. It takes more work to break into the 13s up here. My setup should have been 13.5 easy.
Old Sep 2, 2010 | 05:50 PM
msonia03's Avatar
dragtimes da calc says i shoulda run a 14.488 @ 97.362mph
