Drag Racing Kindle Racing and Dalcorp Racing
Proper launch ss/tc
Old Nov 1, 2012 | 11:01 PM
Igofast's Avatar
Proper launch ss/tc
Ok I'm ready to take her to the track what's the best way to launch? I raced my gf in her 09 mustang gt and instead of popping the clutch I eased off then mashed the pedal after I started rolling a little and I smoked her. But just curious to how everyone else races from a dig? To get the least tire spin as possible. I probably sound like a noob so if you're just gonna talk **** don't even post anything. I'm used to trucks not stick shift race cars, you gotta start somewhere!
Old Nov 1, 2012 | 11:18 PM
Wert842's Avatar
I slip the clutch too until it grabs and let er rip from there. If there's a water box there and you can't avoid it, get on the edge of the water box and do a light spin to throw the water off. Your first couple runs you might spin the tires and if you do, just lower the tire pressure until the hook good enough. My street tires were worthless even with 10lbs in the front. My nt05s hook amazingly good at 18lbs of air.
Don't expect to be a pro your first run. These cars take a while to get used to the launching part. Just have fun with it.
Old Nov 1, 2012 | 11:19 PM
BlackARCA06's Avatar
Exactly what you you said about easing into it, Launch control is nice on these cars but at the same time sucks cause all you do is spin.
Old Nov 1, 2012 | 11:23 PM
Wert842's Avatar
Haha. Launch control sucks at the strip, but its a little different when it comes to street. Traction completely off is the best though. I drive with it off all the time and it feels so much better once you get the hang of instead of just roasting the tires.
Old Nov 1, 2012 | 11:57 PM
cranemaster's Avatar
After 5 runs my best 60ft was 2.6... They ain't no Hondas to launch lol
Old Nov 2, 2012 | 07:12 AM
Yea Ive only used it 1 or 2 times. lol
Old Nov 2, 2012 | 12:53 PM
Igofast's Avatar
Cool cool I'll keep practicing that then. I need better track tires though I only have street tires
Old Nov 7, 2012 | 05:14 PM
VapeWI's Avatar
Yea do what these guys said and easy off the clutch till you catch. Then most likely your have to peddle it a little bit in 1st. Because I don't think not spinning is an option unless of course you have DR's. Good Luck!
Old Nov 7, 2012 | 05:18 PM
slapbetcommissioner's Avatar
I find that reving her at about 2000-2300RPM Locking down the Ebrake and letting out the clutch slip a bit to put some load on the tires keeps it consistent on street tires. Light goes green drop the ebrake and easy onto the gas. At least i blow the tires off less th is way.
Not that im getting epic 60Fts but i am consistent
Old Nov 7, 2012 | 06:08 PM
I found that launching n the street with street tires is way easy and has me at better 60fts then at the track.. Our track is so damn sticky it's a whole other ball game.
Old Nov 7, 2012 | 06:16 PM
BlackLsCoupe's Avatar
**** i just launch control it. dont care about the tire spin since it does it for a quick sec then i short shift from first to second i never rev out 1st to high. people tell me dont do it, i still do and NLS and put down some decent times stock than some lightly modded ones did
Old Nov 7, 2012 | 06:36 PM
gotboost?17's Avatar
Nothin Stock
mods?^
Old Nov 7, 2012 | 07:40 PM
Originally Posted by gotboost?17
mods?^
just GMS1
for example. friend had catless muffler delete trifecta 21psi and intake couldnt break 13.9
Old Nov 7, 2012 | 10:42 PM
13.4 @ 112 is pretty good for GMS1 lol. I got 108MPH traps with 2.6sec 60fts so I geuss planets align run 112mph? lol
Old Nov 8, 2012 | 08:15 PM
ask the guys from the CED 2011 meet thats when i ran that, usealy trap 110-108
Old Nov 8, 2012 | 08:27 PM
Dart_SI's Avatar
rev to 7K
side step that clutch.
lol.
actually, i just launch at 2.5k and gradually floor it. seems to work best for me.
Old Nov 8, 2012 | 08:54 PM
cmiller8006's Avatar
It's hard to explain how to launch it. Much easier to show someone in person. Wish I would have made a video of the tach and foot work. I have pulled many 2.00 60' times on the stock tires and even an all season tire. A key is not only the slipping of the clutch and progressive gas pedal movement but how the tune is set up. If you have it set up for 100 percent in first I will just say good luck. I had first gear set at 50-60 percent and that's it.
Old Nov 8, 2012 | 09:37 PM
Gobolt210's Avatar
I thought you had a video of some footwork up before? i rem trying to imitate it with half the amount of torque an no other track prep lol.
Old Nov 8, 2012 | 10:09 PM
I never did.
Old Nov 11, 2012 | 08:19 PM
skip_jones's Avatar
drive it like you stole it!!
Old Dec 21, 2012 | 09:50 AM
Nfamous60's Avatar
wouldnt you want to launch your car where your horsepower and torque curves are closes to each other. Yes this does involve a dyno sheet.
Old Dec 21, 2012 | 10:01 AM
Terminator2's Avatar
You ran a 13.4 and trapped 112 with a a GMS1 tune? I call BS. I want a video showing proof. I converted my car to GMS1 myself 4 years ago and there is no way that my car would have trapped more than 104 with it. The best I have seen is 106 in that is with a negative DA at the track.
Old Dec 21, 2012 | 10:18 AM
Sox-Fan's Avatar
Got Brakes?
^^ this guy tuned me. My car is far faster at the drag strip now. He cut a ton of torque out of first gear and that helped considerably. I'm still only launching at 1200 to 1500, slipping the clutch and still have a ton of wheel spin, but it's better than before Term worked on it.
Old Dec 21, 2012 | 10:31 AM
prevsrt4owner's Avatar
Yeah, that trap is pretty crazy for that tune, lol. The 13.4 is believable, though.
Old Dec 21, 2012 | 10:36 AM
padlock's Avatar
do you know what percent tq your running in second? From what I hear 50-65% seems best in first, but I'm curious as to what most people run second at. I'll be experimenting a bunch this summer with AutoX coming up (which is all 2nd) but its nice to get a good starting point to work off of.
what tires and size are you on too?
