Racing with an auto?
i am not really going to try to bring my stock auto 2.4 to the track any time soon. im just curious about the technique you would use if you were going to race.
anyone have any input or experience with this?
What type of racing? I would assume drag. if that is the case I know it can be done no problems with an auto but as for tips I have none to offer. If you want to race around a track an auto isn't the best choice but it could still be fun. I wouldn't really recomend actual racing (as in with other cars) around a track though the risk of a crash is pretty high, a few laps alone however would be real fun.
yeah, dont shift through the gears, that usually makes you slower and more inconsistent(i race my auto focus) and put your brakes down all the way, bring your throttle up(not to the floor) then right as you want to go, let off the brakes and apply the gas at the same time.
My technique with my 2.2:
Shifter in "1" or "L"
Brake to the Floor
Throttle to the floor
Red
Yellow
Yellow
Yellow (Release Brake)
Green
When you get to about 65mph, knock the shifter back into D
Dont let off the gas until you get all the way to the end
Brake to the Floor
Red
Yellow
Yellow
Green
Actually gas shouldnt be to the floor. It should be at just below the rpm your torque converter is rated for. A safe bet would be under 2500 rpms. If someone knows the actual number that would help.
Put it in D, Brake to the floor, throttle up to 2250ish rpms. When the light goes green release the brake and mash the gas pedal to the floor.
edit: The L to D method might work. If hack has done it before with no problems I dont see why not.
in my 2.4 the fastest way i tested was in L mode thru 1st and 2nd gear then finish the race in I mode. i hold the throttle to about 2k rpms and let off the brake at the second to last yellow light.
Originally Posted by HackAbuse
I have done 20 runs at the track in one day and used my technique every time
I have the second highest 1/4 times for the Auto 2.2
I have intake and exhaust, and my tim was 16.40@83.5mph /w 2.4 60'
The best auto 2.2 does 16.35
I ran the same exact time.....Spun through all of first and had to let off it a little though. I did what you do and started in 1 then went to 2 then to D. All I have is an Intake....haha and about 200 lbs worth of system.
i dont get how you can rev your engin with the break on.. i use to be able to do that with my old car and now with a cobalt.. when i have my foot on the break and i rev it .. the car either dies or sputters... should i only do that in 1???
-drew
-drew
