suggestion on keeping the wheels on the track?
well i have a bone stock SS/sc and recently went to the 1/8 track near me. On the launch i had a lot of trouble keepin those tires down. any suggestions on what has worked for you or others?..i hear suspension helps a looot.
solid motor/trans mounts....traction bars....CA bushings (dont recomend this, but it works in the short term)...torque dampener....some new rubber!
the solid mounts and new rubber are your best bet
I found them. It's a good idea too.
http://www.mastercraftseats.com/limitstraps.php limit straps for front end
http://www.jegs.com/i/Air%20Lift/022/60844/10002/-1 drag bags for rear end
I found this on another forum
"I bought a package of 4 Coil Spring Stabilizers at Autozone, part number 81492, made by Suspension Solutions. They provide 2.5 inches of separation between coils."
You just jack up the car and insert the spring rubbers and it keeps them from compressing.
Well if it weren't for NASCAR I probably wouldn't think about it, but it's just a rubber spacer that goes in between the springs and when the springs get let down off jack they wedge the space and keep the spring from compressing more.
Pretty simple, same as drag bags.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
