Superchip track time
First superchip track visit... 13.6@106
after that pass they wouldn't let me go without a helmet. I had a 2.2 60' and did not use nls. Next visit will go all out first pass
2.0 is very doable on street tires. I was running 20lbs in the fronts (all seasons) launching at 22 and taking it out of hole easily limmiting tire spin and not much worry about a bog. dont go crazy on the burn out just enough to clean the rocks off. good mph at 105. should be around the 13.3-4 range if you can cut that 60 back some. If you havent tried it I suggest footballs. not a huige help but can make it easier to get down the track.
josh
josh
Nice pass......... It's funny I forgot and didn't NLS either on my passes , I only have 4 total in a cobalt and 2 were stock . I know the Superchips tune will be good for 13.1 -13.0's with a good 60' . The tracks around here open in a couple weeks so i will see if the downpipe helped as well.
