Drag Racing Kindle Racing and Dalcorp Racing
Traction VS Me
Old Oct 14, 2006 | 10:02 PM
lsjwannabe's Avatar
Traction VS Me
track prep was shitty, it was my first time there car had full tank, full weight, stock tire and 35# of pressure in them. Every run i would spin through second was not a good time.
Old Oct 14, 2006 | 10:04 PM
lsjwannabe's Avatar
i was 212 and it was not a purple camaro that was me i was racing a purple camaro.
Old Oct 14, 2006 | 11:22 PM
IonNinja's Avatar
damn is that a 15.5@103? how is that even possible!
Old Oct 14, 2006 | 11:28 PM
lsjwannabe's Avatar
i did 15.002 at 105 lol. I would spin till like 60 mph the catch and shoot like a rocket. i think i am offically the worst driver though.
Old Oct 14, 2006 | 11:32 PM
R&C_rallySS's Avatar
Holy hell! I run 14.6 at like 98 mph. Thats strange.
Old Oct 14, 2006 | 11:36 PM
lsjwannabe's Avatar
i know i went down with a bunch of my buddies they have mustangs and camaro's and in the qauter they would beat me but i would out trap them by a lot.
Old Oct 15, 2006 | 08:03 AM
IROC R/T's Avatar
When you spin your tires your MPH is overly inflated. If he would have hooked his MPH would not have been that high.
"track prep was shitty, it was my first time there car had full tank, full weight, stock tire and 35# of pressure in them. Every run i would spin through second was not a good time."
You know with street tires track prep does not really make much of a difference- especially on a car like yours where it will spin regardless on the stock tires.
Old Oct 15, 2006 | 10:37 AM
lsjwannabe's Avatar
thing is i trapped the same with a 3.2 60ft and a 2.6 60 ft so it doesnt make sense.
Old Oct 15, 2006 | 10:43 AM
lsjwannabe's Avatar
i can go out on the street and powershift second and get traction at 50 at the track it was almost all of second gear.
Old Oct 15, 2006 | 12:58 PM
Pablo's Avatar
Man your 60ft is half a second of and that is not due to poor traction. You achieve 2.1-2.3 60ft's on street tires in pretty much any car by leaving out of the hole like a granny, and in second gear omly give 75% throttle if you're spinning. What you want to do is to try and get 0 wheel spin in the first 2 gears, just enough throttle to keep the car accelerating without breaking loose, it's all in your right foot.
Old Oct 15, 2006 | 02:56 PM
lsjwannabe's Avatar
only problem is that i am on stock clucth and sometimes it doesn't like that and it will slip.
Old Oct 15, 2006 | 02:57 PM
lsjwannabe's Avatar
i was leaving at 1500 rpms and feathering first till 5,000 then flooring it from there on.
Old Oct 15, 2006 | 03:18 PM
Pablo's Avatar
Don't ride the clutch, just ease out of the hole and then gently accelerate with your foot off the clutch, just like taking of from a stop sign, your clutch should not slip at all. Leave at 1500rpm and lightly feather for just a split second and then gently accelerate through the rest of the gear and shift into second and just modulate the throttle.
Old Oct 15, 2006 | 03:26 PM
lsjwannabe's Avatar
i was on and off the throttle in second gear on some of the runs becaus ei thought the clutch was slipping but it was just wheel spin. It is very hard not to spin the tires in first gear i need to screw with my tune and cut down some boost in first gear.
Old Oct 15, 2006 | 04:15 PM
blackphoenix's Avatar
hey don't worry about it.. i'm having the same problems.. and i'm on drag radials.. they will not hook up at all. i don't launch hard.. feather it out.. and they still spin.. i honestly think it's crappy track prep.. why would my tires hook on the street and not the track? doesn't make any sense to me. i was also trapping like 102mph.. and running a 15.3. that was with me spinning the tires till the 1/8 of a mile mark.
Old Oct 15, 2006 | 04:17 PM
lsjwannabe's Avatar
well if anyone in michigan wants to chime in they can tell you lapeer is not the best place to run at.
Old Oct 15, 2006 | 06:29 PM
Asstyme's Avatar
What R your mods ?
Old Oct 15, 2006 | 06:59 PM
lsjwannabe's Avatar
2.5 pulley, hp tuners , 60# injectors, and trans axle mounts and cab's. All for a grand total of $700.
RaginChopsuey
Oct 27, 2015 01:27 PM
CudaJoe
Oct 5, 2015 11:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
RyGuy
Sep 21, 2015 10:03 PM
