what size drag radials to put on 17" ss/na's
I need to know if i can swing 275/40/17 DR's on a stock redline rim with no spacers? I have stance coilovers so i can raise them to the moon but i'm more worried about rubbing the coilover. My performance shop has them in stock and i already have a appointment with my tire guy for my other car so please tell me your thoughts on this ASAP.
Thanks in advance!
Thanks in advance!
i'd be afraid to go THAT wide... plus you'd probably hit the strut itself... BFG makes a drag radial. i've got a thread in drag racing called traction combos that has a bunch of stuff listed...
On the road i can spin them no problem at 40mph like my stock conti's but on a well prepped track i couldnt get them to spin in 1st and 2nd with still 21 psi in them. Thats why i said you dont ''need'' wider unless you have crazy power, seem your case with the EFR.
So i'm gonna get 9" wide rim with 275/40/17 micky thompson dr's
The last time I used them it was 95* out and about 25% throttle in 2nd it would shred them lol.. I dropped the pressure down to 15 psi also and you could hear them like wrinkle and flapping while spinning haha. They do work alright if you heat them up a bit though.
