Drag Racing Kindle Racing and Dalcorp Racing
Wheel/Tire combo for drag racing
Old Apr 1, 2011 | 11:48 AM
80vetteL82's Avatar
What are you guys, that go to the strip pretty often, using for tires? Ive run my SS/TC probably a total of 15 times on stock Conti's. I was recently invited to be on a team for a charity bracket racing event. Its a month from now, and I havent decided if Im gonna be ready to bring the Vette yet or not. If not, Im going to bring the Balt. However, I want to put some rubber on the front that will get me out of the hole better.
Im not looking to buy a set of 4 tires, so I was considering getting a pair of slicks and a pair of front wheels that will fit over the stock SS/TC brembos. Im a little concerned with the slicks on stock axles, although Im only GMS1 so Im not making crazy power....
What Im wondering is what are some other options out there if I dont go with slicks? Is there a good drag radial to use? How about Nitto's?
If you could, just list what your using, and whether or not you are using stock wheels.
Thanks!
Old Apr 1, 2011 | 12:03 PM
EXsoccer1921's Avatar
if you want something to switch on just for that day and maybe if you have an extra set of 18s
Mickey Thompson Performance Tires & Wheels
Old Apr 1, 2011 | 12:13 PM
80vetteL82's Avatar
Slicks will be alright on stock axles?
Old Apr 1, 2011 | 12:15 PM
better than a drag radial. a drag radial with its stiffer sidewall is actually more prone to wheel hop and axle breaking. slicks will wrinkle slightly and absorb the vibrations/hop/wheelshake that would otherwise go through your axles.
Old Apr 1, 2011 | 02:12 PM
ixxgh0stxxi's Avatar
isnt that what cmiller ran in his car at some time?? and what size do you get couse im considering these just for the track.
Old Apr 1, 2011 | 02:14 PM
he was running 17s i think but yes before he switched to 15s it was these. if you want to run them on the stock tcs a 25/7/18 would work. or if you had a 17 you could do the 26/7/17
i would suggest finding a 17 if you can. cause its a 1" taller tire on a 1" smaller wheel. thats a full inch gained of side wall height
Last edited by EXsoccer1921; Apr 1, 2011 at 02:14 PM. Reason: Automerged Doublepost
Old Apr 1, 2011 | 02:17 PM
1LowLS's Avatar
I use BFG DR's.I like em.I didnt notice alot of wheel hop and they netted me a 2.0 60'
Old Apr 1, 2011 | 11:21 PM
smithboy76908's Avatar
I use 24.5 x 8 x 15 M/T Drag Slicks. A good burnout and they hook like glue.
Old Apr 2, 2011 | 11:37 AM
80vetteL82's Avatar
Good stuff guys, thanks.
Unfortunately with the Brembos 15"s wouldnt be possible, but that would be nice.
Old Apr 2, 2011 | 11:40 AM
WannaBFast5's Avatar
I'm using stock G5 GT rims with BFG DR's with a wheel spacer. Love them. Got my first few runs with them last night and they work good.
Old Apr 2, 2011 | 05:26 PM
Stik09's Avatar
BFG work ok but dont run around boosting on the street or they will tear up fast.... I mean real fast, like melting butter fast. If you only use them at the track after heating them up they will last a while. running the bfgs at 18 pounds I busted a 1.89 60" but then while working out the kinks on my E85 tune I completely trashed them on the street in about dozen good floggings.
I going back to Hoosiers for Drag radial. I have cut a 1.75 all day in a front wheel a FWD car. I bought some 17x8 5Zigen fn01rc and had them redrilled 17 lbs and decent tire choices....
To keep from wheel hopping even with tranny mounts I roll through the water by about 2 feet and then yank the ebrake and dump the clutch. When I see tire smoke I let out and line up...No hop at all that way.
Old Apr 4, 2011 | 11:41 AM
KillinKrullin's Avatar
borgat wheels will grind you out a pair of rims to fit over anything. so you could run 15's with the brembos but you will pay the price for it, and i dont know how soon they could have them ready for you. oh btw they are 8lbs wheels
@ 1LOWLS: i run a 2.0 60ft on my hankook rs-2's, and i havent heard of anyone running lower with DR's yet, so to me drag radials are pointless.
I'm about to get some slicks but im still debating on a 24.5 or 26 tall tires.
Old Apr 4, 2011 | 11:47 AM
jmfselu's Avatar
i really dont thing 15's would ever fit over brembo's period..the brake rotor is 12.5" and the brake caliper sticks out a good inch/inch and a half...that would be epic to see 15's over brembos lol
Old Apr 4, 2011 | 12:06 PM
WSFrazier's Avatar
If your serious enough about drag racing that you want a good slick, then you don't want/need the Brembo's.
Old Apr 4, 2011 | 12:21 PM
Im tellin you man, they made me take like 30 different measurements, they can make anything fit, and fit right.
Bogart Racing Wheels
Old Apr 4, 2011 | 06:22 PM
jmfselu's Avatar
did you order a set? if so i'd love some insight on them!
Old Apr 14, 2011 | 10:33 PM
BooSSted's Avatar
No, they can't. The radius from the center of the hub to the outside edge of the Brembo is going to be more than 7.5". Therefore it is physically IMPOSSIBLE to fit a 15" rim on there. I don't even think you can get a set of 16" over them.
Old Apr 15, 2011 | 08:20 AM
Stik09's Avatar
CCW swears after seeing the measurements that a 16 will fit for sure. But your looking at 700 per wheel to your door probably. To much for me.....
Old Apr 19, 2011 | 03:36 PM
I didnt know they were that high , thought the issue was what the distance from the mounting surface of the rotor. anyways. im pretty sure they can make a set still fit, on a rim size the bead has to be at 15inch circ. but the middle of the rim can be higher if you are using wrinkle walls.
it would be interesting to see if they could pul it off. some one with a turbo call them up and send your measurements in to see if they can make it fit around the caliper.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
