Drag Racing Kindle Racing and Dalcorp Racing
Where are my 13's?
Old Sep 21, 2006 | 06:35 PM
djt81185's Avatar
Originally Posted by sethallen
and i don't need boost bypass....gm stage 2 solves that issue
actually the gm tune still has boost limits in it...it is 210 kpa or roughly 16psi the map maxes at 256kpa
Old Sep 21, 2006 | 06:36 PM
IROC R/T's Avatar
Also I wanted to say I got better 60' times messing around with the tow vehicle- a full size 4x4 suburban was getting consistant 2.3's- you need some work on the launch!
Old Sep 21, 2006 | 06:40 PM
IROC R/T's Avatar
Not sure how your MAPS work but the old two bars would only go to 14.7 PSI and after that you had to use a 3 bar unit off an old Turbo TA to get the calibrations right- I wonder if the GM guy's know why they sell so many of these map sensors .
Old Sep 21, 2006 | 06:46 PM
djt81185's Avatar
it seems like it is a 2.5 bar sensor
Old Sep 21, 2006 | 06:52 PM
cobaltstg2's Avatar
i have the same problem gettin into those 13 i traped a 102 lastnite but only got 14.45
Old Sep 21, 2006 | 06:53 PM
cobaltstg2's Avatar
rob said my problem was stock gm clutch it is slippin alot
KillerNutz's Avatar
60' 2.344
330 = 6.29
1/8=9.419
1/8mph=78.00
1000=12.125
1000mph=90.67
1/4=14.3940@99.35mph
60ft=2.312
330=6.437
1/8=9.591@77.58
1000=12.288@91.49
1/4=14.531@101.13
There's your 13's. I assume the reason you had a quicker 60' on the second run is because u used less throttle therefore less wheel hop. Problem is once you hooked up you were goin slower than the first run.
Old Sep 21, 2006 | 08:09 PM
sethallen's Avatar
thank you killer...that may explain it.....so in other words, some DR's could really help me a lot, and i really need to work on my launch....not necessarily just my 60', but the first 330'
and iroc, i know what youre saying about a worse 60' and a higher trap, except my 60' was lower, and my trap was higher.
Old Sep 21, 2006 | 09:22 PM
IROC R/T's Avatar
I would not read too much into a mile or two difference- a headwind verses a tailwind could cause this too.
You have to try slicks- once you try them you'll realize your wasting your time without them and you will get way more consistant.
Old Sep 22, 2006 | 05:48 AM
SilverSS/SC's Avatar
Is your clutch slipping ? When my clutch was going , it was hurting me getting the car moving . In 3rd it would still pull strong and I would still MPH really good .
That would expain your good mph and slo ET too .
Old Sep 22, 2006 | 06:13 AM
  #36
2K5SS/SC?'s Avatar
If the clutch is slipping, that could be a problem. Usually to get a better 60ft time I stay at idle while staging, and hammer it off the line using the last yellow as my go. I've only been to the track once and I cut 2.2 60' with ease.
Old Sep 22, 2006 | 05:18 PM
  #37
sethallen's Avatar
but how would you hammer it without wheelhopping and spinning like crazy????????
also, what did u run?
Old Sep 22, 2006 | 08:13 PM
  #38
tityrous's Avatar
thats what i do man and its really the only way to launch the car without tirespin but when u hammer on it it still spins lol these cars are hard to launch just pracitce it more ...
