2.0 LSJ Oil Filter Change.
Old Feb 14, 2008 | 01:02 AM
boostbum06's Avatar
Unhappy 2.0 LSJ Oil Filter Change.
I know this is going to sound rather stupid, but i must know, how in the hell do you get that oil filter composite out? Im pretty sure i found where its located its just impossible to get a wrench or ratchet big enough down in that space. ANY help would be great.
P.S.- I'm running Royal Purple 5w-30 in my LSJ right now and i love it! no more dry starts because it's made so that it leaves a coat of lube on your cylinder walls when the engine is shut off.
Old Feb 14, 2008 | 01:04 AM
eurochevy's Avatar
get the size of the socket u need..then jst get a long extension attatch it to a ratchet and have at it...then replace filter..wiggle ur way back into place..and tighten up again useing same way u took it out...
ps. its under the supercharger to the right..its kinda hard to see but it just looks like a big octagon ..and the entension will have to go in between some vacuum hoses
Old Feb 14, 2008 | 01:07 AM
MarcS's Avatar
The Stig
I always put the socket on the filter housing first then connect it to the extension. It takes a little bit of practice.
Old Feb 14, 2008 | 01:33 AM
syP's Avatar
syP
https://www.cobaltss.net/forums/how-guide-43/oil-change-how-picture-22848/
Old Feb 14, 2008 | 06:11 AM
Brandon97Z's Avatar
i use a open ended wrench....its a bit of a pain to get to
Old Feb 14, 2008 | 08:21 AM
MarcS's Avatar
The Stig
Exactly
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Sep 28, 2015 12:51 PM
