2.2 clutch and axle question
Old Sep 25, 2009 | 04:07 PM
09blackonblack's Avatar
can you use the sxles from an ss to replace the crappy ones in the base models for more strength? or is there any vendors who make them for a 2.2
how about the clutch... anyone have a suggestion for a bolted 2.2?
Old Sep 25, 2009 | 04:08 PM
JohnnySasakiMGS's Avatar
It think the SS and the 2.2 share the same axles...
Old Sep 25, 2009 | 04:29 PM
if so.... no wonder you guys are always breaking them...
Old Sep 25, 2009 | 05:20 PM
I think I might be wrong though. http://www.gmpartsdirect.com/catalog/frameset.cfm
Go to Cobalt and search axle.
Last edited by JohnnySasakiMGS; Sep 25, 2009 at 05:20 PM. Reason: Automerged Doublepost
Old Sep 27, 2009 | 11:21 PM
Old Sep 30, 2009 | 04:34 PM
v10demon89's Avatar
Now if an SS axle could be used to replace stock would it spline into an LS hub?
Old Oct 1, 2009 | 07:12 PM
CobaltLT's Avatar
Nope. Better off getting the Driveshaft axles.
No they don't, but the SS axles are horrible as well.
Your only hope is to get the Driveshaft axles. www.ottperformance.com sells them for the 2.2.
As for a clutch, I would go with a Spec brand...not sure what stage since I don't know how much HP your goal is but I would suggest a Stage 2+, thats what I have along with a Spec flywheel.
Old Oct 4, 2009 | 01:24 PM
is that the only axle options? 1 mm doesnt seem like it would give you much more protection against breakage
Old Oct 5, 2009 | 01:06 AM
CobaltLT's Avatar
Yes, they are rated to handle up to 400hp...heres the link to them on their website for specs. http://www.driveshaftshop.com/pdetail.php?pid=67
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
