2.2L 5 spd Trans Fluid?
Old Feb 19, 2010 | 08:17 PM
Foximus's Avatar
My car now has 100,000 miles on it, and as soon as the weather stops sucking, Im going to replace the trans fluid. I know its 1.8L, but Im looking for whats recommended to go in (aside from Royal Purple. I will NEVER run that)
Go with the $4/L stuff from GM thats semi synth, or is there something better out there?
Old Feb 19, 2010 | 08:20 PM
slowswap's Avatar
Dexron 3 ATF.
MUST BE PURE DEXRON 3. DEXRON 3 COMPATIBLE WILL EAT AWAY AT YOUR SYNCHROS.
Hope that helps. And yes the F23 Getrag manual transmission does use ATF.
Old Feb 19, 2010 | 08:38 PM
Foximus's Avatar
I knew it was ATF. But So I need to find a Pure Dexron 3 fluid then?
Old Feb 19, 2010 | 08:58 PM
slowswap's Avatar
Basically find a Dexron 3. Don't get like a Dexron 3/4 or a fluid that says it's compatible.
Old Feb 20, 2010 | 02:22 PM
montecarloman's Avatar
Go to a GM dealer and ask them for 2 bottles of
Manual Transmission Fluid GM P/N : 88861800 (US), 88861801 (Canada)
Its really the only thing your going to find other than the royal purple or redline brand stuff. And because its the direct GM recommended fluid you don't have to worry about screwing up your trans. My 2 cents
Old Feb 21, 2010 | 12:25 PM
xxxxsh4d0wxxxx's Avatar
Wrong.
It is not P/N: 88861800
It's DEX-VI ATF.
Old Feb 21, 2010 | 04:08 PM
07cobaltguy's Avatar
When i went to the parts department, the gentleman there looked it up and directed me to the GM syncromesh, I dont off hand have the part number. Thast what ive been using and it works just fine. so far.
Old Feb 21, 2010 | 04:28 PM
If you go to syncromesh or gear oil you will burn it up from lack of lube. The transmission is designed for ATF, which is very thin. Thick oil like syncromesh or gear oil can't get through the lube passages sufficiently and will cause it to overheat from lack of lube. Feel free to try synthetic ATF if you feel so inclined.
You've been using the wrong ****.
I have the Cobalt repair manual, and I also work at a Ford dealership, they all use the same program for information (AllData), and I know it says P/N: 88861800, both in the repair manual, and at my work, which is GL, but that is not right.
Old Feb 21, 2010 | 10:37 PM
slowswap's Avatar
Huge :facepalm:
Old Feb 22, 2010 | 12:38 AM
Originally Posted by slowswap
Huge :facepalm:
Old Feb 22, 2010 | 03:48 PM
beamer1341's Avatar
so you cant use like a synthetic dex merc trans fluid?
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
ThoR294
Oct 4, 2015 08:44 PM
