2nd Gear???
Old Mar 4, 2007 | 10:43 PM
YelloEye's Avatar
2nd Gear???
Well I was pulling out of Walmart today and went to shift into 2nd. It did its normal engage thing then jumped back out, I figured well it must not have been completely engaged right? So at the next light I grabbed the shifter and pulled back and held it firmly into 2nd, it popped back out and made the grinding gears sound. So for the rest of my drive home, no 2nd gear. It works for decelerating but not accelerating. I'm guessing it just cut the acceleration side of the gear to where it will still grab for decelerating, like a saw blade. Guess tomorrow I will be trying to get it under warranty.
On a side note my e-brake broke on Friday too, the spring that pushes the button back out so that it locks must have broken or something. So I took the brick handle off and now have to lock it by pushing on the part that actually grabs the e-brake teeth.
Interesting how this all happened around 25k miles....
Old Mar 4, 2007 | 10:45 PM
stotte20's Avatar
man that sucks i hope your dealer is cool and will not try to screw you by saying its been abused
Old Mar 4, 2007 | 11:03 PM
YelloEye's Avatar
I hope not too cause I've taken it to the 1/8th mile track here.....10.4 is what I got there btw.
Old Mar 5, 2007 | 01:02 AM
tricky1's Avatar
HAHAHAHAHA
Sounds like it's becoming a common problem...I laugh cuz the same happened to me...GM Covered it...they replaced the 2nd Gear gearset/synchros, and a plastic piece that broke off the shift fork. They also replaced my clutch cuz it was half worn at 5609mi
Old Mar 5, 2007 | 01:17 AM
silver06cobalt's Avatar
Yep same here but it was with my 3rd gear. Seems like its becoming quite a widespread problem.
Old Mar 5, 2007 | 01:19 AM
Zero Six SS's Avatar
I have to say, my third gear's starting to do that...it's done it a couple times.
Old Mar 5, 2007 | 02:16 PM
YelloEye's Avatar
Well I hope its under warranty, I have an appointment tomarrow morning so I guess we will see then.
Old Mar 8, 2007 | 03:05 PM
Brandon97Z's Avatar
Let us know what the results are. I have the exact same problem, stays in gear under deceleration but not acceleration.
Old Mar 8, 2007 | 03:32 PM
DressBoyBlues's Avatar
i have the same problem. they believe my synchroniser is bad in 2nd. ya im getting warranty to so i dont care to much as long as it gets fixed but my friend was telling never leave my hand on the stick while im driving b/c ill grind it down. my inner pinion seal is leaking as well on the drivers side WARRANTY
Old Mar 8, 2007 | 04:23 PM
YelloEye's Avatar
Well she's still in the shop, I called em today and they said they are waiting on parts, doesn't sound like its coming out of my pocket either. w00t warranty! I'll let you guys know what was wrong when I get her back.
Old Mar 14, 2007 | 12:59 PM
YelloEye's Avatar
They ended up replacing most of the synchros, I'll post up the list when I get it out of my car.
Old Mar 21, 2007 | 12:31 PM
basketball0028's Avatar
Originally Posted by tricky1
HAHAHAHAHA
How did you know that your clutch had to be replaced. because i have 5500 miles and my clutch won't catch till the pedal is almost all the way out
Old Mar 23, 2007 | 08:32 PM
ls_jbody07's Avatar
Dude I did the same thing in my 03 Cavy, how hard did you hit 2nd before you noticed it...cause you totally pusted 2nd gear in half and ripped out the gear syncros. I had mine fixed by warranty but it was like $4300 if it wouldn't have been so good luck.... oh yea ask for the broken gear I put mine on a hemp necklace and have it around my neck as a symbol of blowing the doors of a type r integra when I did it!
Old Mar 23, 2007 | 08:56 PM
yellowcobaltss05's Avatar
I have that same exact problem with 2nd too. The dealership said they will warranty it as long as I put back the stock shifter
Old Apr 30, 2007 | 05:50 PM
Brandon97Z's Avatar
Can those who've had this problem please let me know what all was changed when you took it to the dealer. I'm having exactly the same problems and dealer tried saying my twm shifter streched the shift cables and thats whats causing it. Although i addimatly told him that the TWM has been fine for 15k miles and that many others have had the exact same problems and it was the shift forks/syncros. He said he'd talk to the tech and call me back which hasn't happend yet so hopefully they descoverd i was correct and started taking out the trans to check it out.
Old May 2, 2007 | 07:20 PM
RallyYellowMiniVette's Avatar
Mine just started popping in and out of second and fourth last week I don't know what to do I'm pissed. My first thought was the syncros but I don't know. Please keep me updated on what is going on with your cars.
Old May 9, 2007 | 03:12 AM
bustaSS's Avatar
hey I have driven my cobalt 4 500 miles. right now when i upshift into 2nd or 3rd it feels different from when i downshift into 2nd or 3rd, it kinda feels like the sycros are out of wack or somthin when upshifting did any of you experience this before the stick started to pop out?
Old May 9, 2007 | 04:23 AM
Brandon97Z's Avatar
Not really 2nd started grinding more often really only thing i noticed. I'm still fighting with the dealer on this. Its my uncles dealership but i'm trying no to pull that string and take care of it on my own and showing them they can't try and rip people off.
They look at it and first claim my TWM shifter streched the cables and that was causing it not to stay in 2nd. Also saying they want to replace the TWM with a stock shifter ,saying it will only happen again over time , and have me pay for everything including the rental. I say i don't think thats the problem but go ahead and install the cable to see if it fixes. Nope doesn't work, like I told them. They call back say they want to install the stock shifter i say sure but i don't think thats the problem. They then say if they put the stock shifter on even though it may or may not fix the problem i will still have to pay for the stock shifter ,$225. And they insisted on doing this before looking further into the tranny. I say i shouldn't have to pay for that he disagrees and says thats what GM's instructions were to do. I said we'll discuss that later just see if it fixes it as anymore just want to get the thing fixed.
Sorry for the long storry but just letting know how my dealer experience has been so far.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
riceburner
Oct 2, 2015 05:47 PM
