4t65e
Old Sep 14, 2007 | 01:26 AM
j27's Avatar
j27
4t65e
In my gm bild book I came acrose a section where it seas you can manualy shift it if you wier it up to two switches to controle the solanoid. how could yoy do this?
Old Sep 14, 2007 | 01:31 AM
Cobalt Mav's Avatar
Try typing it so that people can understand please.
Not trying to be an ass.
Old Sep 14, 2007 | 01:41 AM
impulseballer's Avatar
lol its not that difficult to read. translation:
In my gm build book I came across a section where it says you can manually shift if you wire up two switches to control the solenoid. How could you do this?
Old Sep 14, 2007 | 02:54 AM
RollermanDan's Avatar
You have to use a manual shift controller availible from
Here's what is says directly from the GM Build Book:
4T65E SHIFT ALGORITHM
The 4T65E transmission is shifted with two shift solenoids. The ground sides of the solenoids are pin A and pin B in the pass through connector. Pin E requires switched 12V. The shift algorithm of the 4T65E is:
SHIFT ALGORITHM OF THE 4T65E
Solenoid A Solenoid B
1st gear on on
2nd gear off on
3rd gear off off
4th gear on off
An easy and cheap way to shift the 4T65E is with two toggle switches. The toggle switches need to switch ground to pins A and B in the pass through connectors. To operate the transmission turn both switches on. This will put the transmission in 1st gear. To shift into 2nd gear shut off the switch to solenoid A off. To shift into 3rd gear shut off the switch to solenoid B. For 4th gear turn the switch for solenoid A back on.
TCI and CompuShift offer automatic shift controllers that will operate the 4T65E Transmission. These are excellent choices for street strip applications.
An inexpensive alternative for drag racing and occasional street use is the MSD Programmable shift controller part number 7559. (Fig. 234) This controller was developed to shift a Lenco type transmission. With a little ingenuity it can easily be adapted for use on the 4T65E transmission.
Two relays are needed to convert the system for this application. The MSDcontroller needs two inputs a: Launch / Reset and Shift Override. The Launch / Reset button resets the controller to first gear both in electrical outputs and in the shift sequence. The Shift Override button manually up-shifts the controller. In first gear the controller does not output a signal. When the 1-2 shift is made it turns on a 12v signal. When the 2-3 shift is made another 12V signal is turned on. Since the solenoid needs a ground to activate, relays are needed. Ground should be connected to the input of two relays. The Normally Closed output of the 1st relay should be connected to pin A on the transmission pass through connector. The normally closed output of the 2nd relay should be connected to pin B of the transmission pass through connector. One side of the coil of each relay should be connected to ground. The 1st shift output from the transmission controller should be connected to the other side of the coil of the 1st relay. The 2nd shift output from the transmission controller should be connected to the other side of the coil on the 2nd relay. The normally open side of the relay can be used for gear indicator lights. Two lights can be connected to power and the other side of the lights connected to the normally open side of the first and second relays.
When the transmission is in 1st both lights will be off, in second the 1st light will turn on and in 3rd the second light will come on.
MSDProgrammable Shift ControllerPN7559 (Fig. 234)
This is what I have to do my for my new 1400hp engine and 4T65E transmission .
Old Sep 14, 2007 | 03:36 AM
ridemlow03's Avatar
1st gear on on
2nd gear off on
3rd gear off off
4th gear on off
TCI and CompuShift offer automatic shift controllers that will operate the 4T65E Transmission. These are excellent choices for street strip applications. An inexpensive alternative for drag racing and occasional street use is the MSD Programmable shift controller part number 7559. (Fig. 234) This controller was developed to shift a Lenco type transmission. With a little ingenuity it can easily be adapted for use on the 4T65E transmission. Two relays are needed to convert the system for this application. The MSDcontroller needs two inputs a: Launch / Reset and Shift Override. The Launch / Reset button resets the controller to first gear both in electrical outputs and in the shift sequence. The Shift Override button manually up-shifts the controller. In first gear the controller does not output a signal. When the 1-2 shift is made it turns on a 12v signal. When the 2-3 shift is made another 12V signal is turned on. Since the solenoid needs a ground to activate, relays are needed. Ground should be connected to the input of two relays. The Normally Closed output of the 1st relay should be connected to pin A on the transmission pass through connector. The normally closed output of the 2nd relay should be connected to pin B of the transmission pass through connector. One side of the coil of each relay
deffinetly +rep for you for giving all this info. how hard do you think it would be to put the 4t653 tranny in our car and how long?? Im sure you could probaly build a nice tranny to handle like 400whp with slicks for about 2000.
Old Sep 14, 2007 | 03:40 AM
Well the race prepped 4T65-E transmission brand new is worth $7,000. As for putting it in, not that hard. HOWEVER, you do need the adapter plate that is provided by Roush Industries.
Old Sep 14, 2007 | 04:02 PM
j27's Avatar
j27
so ether way you have to have a trasmiton controller
Old Sep 14, 2007 | 05:31 PM
Yes...or atleast I think so.
Old Sep 14, 2007 | 09:32 PM
ridemlow03's Avatar
ive found the 4t65e for about 400 out of sc buicks and all that and im sure they can handle good amount of power stock and im sure it wont cost too much to build up. you have a link to that adapter plate???
Old Sep 14, 2007 | 09:51 PM
This comes straight from the build book:
Adapter Plate — ECOTEC to 4T65 CPT715 GM Racing (Bates)
Only available through GM racing....dunno how you guys are going to manage that.
Old Sep 15, 2007 | 07:14 AM
ridemlow03's Avatar
Alright guys well i been talking to a guy whos been very helpful and patient with me. From what i hear also he's very knowledgable about the 5 speeds in our SS/SC. He told me that him and alot of other saab guys have been running 400hp+ on stock trannies and slicks. He also told me that just dont abuse the tranny and do no 6000 rpm clutch drops. Im guessing the problem with people breaking trannies with slicks even though they have no wheel hop is that they are dumping the clutch way to high in the rpms.
night_throne
Jul 23, 2013 04:34 AM
mr corsa
Jun 28, 2012 11:10 PM
turboLS
Oct 5, 2009 09:00 PM
Turbo06Sedan
May 5, 2008 02:29 PM
