adjustable mASTER CYLINDER??
Old Dec 29, 2010 | 09:16 PM
08CPE?SS's Avatar
i bought an exedy clutch and flywheel.... a few months have past and my second gear synchro is done.... surprise surprise . So i took my car in for it to get repaired under warranty. how ever the shop foreman master tech at my dealership told me that my flywheel was wrong so its not fully engaging he said I should definitley get a adjustable master cylinder... i can not find one for the f 23 trans any suggestions or guidance??
Old Dec 29, 2010 | 09:20 PM
glen229's Avatar
get the adjustable clutch rod from zzp, that will give you the extra pedal release you need, i did a write up on it for them
Old Jan 1, 2011 | 02:31 PM
huckernage's Avatar
someone did a custom and cost me 40$
if you still have air bubble in your line, this item ll be not help you out.
first rule in bleeding be patient
here a video of how to bleed a ion f23. coby f23 use a different fitting. according to me coby should be easier. the use the same process as brake system.
http://www.youtube.com/watch?v=hX_gtDl2-Hc
Old Jan 1, 2011 | 07:04 PM
08CPE?SS's Avatar
i bled it still same problem thanks for the effort, posting on both of my threads
Old Jan 1, 2011 | 07:36 PM
huckernage's Avatar
you did 2 threads. 2 answers you get
Old Jan 1, 2011 | 07:44 PM
08CPE?SS's Avatar
i know i was thanking you for your idea but i already did it when i installed my clutch i m gonna get the zzp clutch rod
Old Jan 1, 2011 | 08:00 PM
huckernage's Avatar
it is not a quarter inch that ll give full engagement.
mine didnt solve it.
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
calo247
Sep 8, 2015 12:29 AM
TurboWood
Sep 7, 2015 11:08 AM
