Anyone having a problem with their Bully clutch?
FYI, I'm sending my clutch back to TAG in the next few days. I've tried installing it twice but it still won't work. Maybe I got a bad one, who knows. Anyhow, they sent me a spacer to make it compatible with my Fidanza flywheel but it will not disengage even with the spacer. The slave cylinder is rubbing on the clutch disc and pressing it aganist the flywheel. Good luck to everyone else, I'm going with either an Exedy or a Spec. Not fully sure yet....
Sorry to hear that you are having the problems. But before you go through all of the trouble of sending it back, why don't you just give Mel a call and see if he can help you out with it. You could be installing it incorrectly. I do know that you have to slightly bend the steel hydraulic line going to the slave cylinder slightly in order to keep it from rubbing the pressure plate. Being as that your fidanza flywheel sticks out farther than the factory one, you probably have to bend it some more.
Later,
Vince.
Later,
Vince.
Later,
Vince.
Later,
Vince.
