Anyone running Royal Purple Synchromax?
Old Oct 6, 2007 | 02:43 PM
Onyxd04Redline's Avatar
Originally Posted by 06REDSS/SC
i dont think you can, but i am not exactly sure on that.
MY bad. For some reason i thought Max gear was ATF fluid
Old Oct 6, 2007 | 02:46 PM
joeworkstoohard's Avatar
Originally Posted by Onyxd04Redline
We can run ATF fluid in our manual tranny's? Cool
i dunno about the IRL, but the f23 in the 2.2/2.4 cars uses ATF instead of normal oil
Old Oct 7, 2007 | 07:55 PM
Supercharged06's Avatar
so what about the ss/sc trannys what kinda tranny fluid can you use does it have to be oem or can moble1 or royal purple be used
Old Oct 7, 2007 | 11:24 PM
06REDSS/SC's Avatar
I would recommend using the Royal Purple MAX GEAR 75w-90
Old Oct 11, 2007 | 09:22 AM
R&C_rallySS's Avatar
How long have you been running the 75W-90 Max Gear Royal Purple stuff? Any problems with it yet?
EDIT POST: I'm finally done with my clutch/flywheel install and holy hell what a differance. I would suggest to anyone to use the Royal Purple 75w-90 Max Gear oil in their tranny! This stuff makes the shifts so smooth its like butter!
Old Oct 16, 2007 | 02:03 AM
bigNO3L's Avatar
Originally Posted by kyyankee
so do the MU3's take synchromax or not this has been debated many times
they take a special gm fluid that most dealers don't carry but the synchromax is a universal fluid that can go in most transmissions
Old Oct 17, 2007 | 06:43 PM
I had Royal Purple MAX GEAR 75w-90 and i highly recommend it to EVERYONE
Old Oct 17, 2007 | 07:58 PM
SSdan's Avatar
How is it coming along...?
Old Oct 18, 2007 | 03:18 PM
That should say "Have" and i haven't had any problems whatsoever
Old Oct 30, 2007 | 06:34 PM
BLKblurr06's Avatar
Instead of tranny fluid. My Ion manual states the manual tranny only needs 1.8 quarts to be filled so it's not bad. I really want to try it.
I ran it for a long time in my old '02 z24, loved the stuff..as stated above, you notice that the shifts are smoother like it slips in better, especially once the motor warms up..
how different is the MAX gear oil than synchromax ?? how much $ per quart? also where are the fill and drain plugs?
Last edited by BLKblurr06; Oct 30, 2007 at 07:02 PM. Reason: Automerged Doublepost
Old Oct 31, 2007 | 11:21 PM
  #36
It's about 10 dollars a quart
Old Nov 1, 2007 | 12:22 AM
  #37
SSKevinSC's Avatar
I have been using the Royal purple max gear 75w90 for about 12,000 miles now and its is great. The shifts are alot smoother. Got it for 10.95 a quart at summit.
Old Nov 1, 2007 | 03:49 AM
  #38
fastfreddy7's Avatar
Wait, so exactly which one is needed for the 2.2 tranny? I m willing to give it a shot, I dont like the notchiness of the tranny, especially when its cold out.
Old Jan 27, 2008 | 12:15 AM
  #39
an0malous's Avatar
Just put some RP Synchromax in today during my axle install.
definately a noticable smoothness in the shifts now
pretty happy with it so far.
i notice a few people posting in nearly every single thread about this stuff saying you have to use max gear 75-90.....if you take a close look, RPs website suggest that all GM vehicles using GM synchromesh, use RP synchromax as the replacement.
I dont think you can go wrong with either, but I did plenty of reading before i chose....and all arrows pointed to synchromax being the best choice for us IMO
Old Jan 27, 2008 | 12:44 AM
  #40
Mr_Slobalt's Avatar
I've had two quarts of it sitting in my trunk for a few weeks now. I haven't got around to shortening an allen wrench to drain the tranny.
Any tips? I want to find a way NOT to hack up a perfectly good allen.
Old Jan 27, 2008 | 04:05 AM
  #41
redlineblueline's Avatar
the 75-90 meets the GL 4 requirement that the stock stuff meets
Old Jan 27, 2008 | 10:54 AM
  #42
an0malous's Avatar
and?
there are quite a few applications listed as needing GL-4, that suggest using synchromax for the RP replacement.
Im just adressing the fact that nearly every thread i searched on here about royal purple had people posting that synchromax isnt good enough.
yet thats the exact oil that RP suggests for our cars.
Old Jan 27, 2008 | 11:18 AM
  #43
06blackSC's Avatar
i'm leary about putting the heavy weight stuff in my tranny where it gets cold around my neck of the woods. Anom, how has driveability been with the synchromax when cold?
Anyone else, how is cold weather driveability with either the max gear or the synchromax?
Old Jan 27, 2008 | 11:22 AM
  #44
an0malous's Avatar
well....it was about -15 lastnight driving home, and the shifts felt like butter.
Old Jan 27, 2008 | 11:30 AM
  #45
RJSS's Avatar
A how to with some good pictures for the SS/SC would make me a lot more enthusiastic about changing this fluid...wink wink.
PS-That was directed at all of you! lol
Also, does anyone know what the recommended interval per GM is for changing the fluid?
Old Jan 27, 2008 | 11:37 AM
  #46
quadracer0387's Avatar
recommended every 25k to change tranny fluid
Old Jan 27, 2008 | 11:47 AM
  #47
boostedss26's Avatar
i was told that our trannys take some special gm tranny ****. Kinda like dodge you gotta run a special fluid
Old Jan 27, 2008 | 12:03 PM
  #48
CJ BadBlackSS's Avatar
hmmm guess i better do that...27k.
so i might just go with the GM fluid since you all can't seem to agree on what we should run
Old Jan 27, 2008 | 12:05 PM
  #49
an0malous's Avatar
From the reading ive done, either max gear or synchromax will work just fine.
after doing a little more digging, it appears synchromax is basically just the same stuff with another additive to extend the life of your synchros.
Old Jan 27, 2008 | 04:34 PM
  #50
Mr_Slobalt's Avatar
What tool did you guys use to drain it?
