auto trans
Old Jan 21, 2009 | 01:43 PM
rockstar014's Avatar
auto trans
i know u can get a auto tran cooler but is it even worth the buy??
Old Jan 21, 2009 | 01:46 PM
sick06cobalt's Avatar
depends... how much do you want to mod your car.. if you want to mod quite a bit i say yes...
Old Jan 21, 2009 | 02:06 PM
HunterKiller89's Avatar
only if you plan on running boost
Old Jan 21, 2009 | 02:10 PM
well im s/c it in april or may soo i prolly should then??
Old Jan 22, 2009 | 09:12 PM
celicacobalt's Avatar
yes if you plan on adding power
Old Jan 23, 2009 | 01:19 AM
red06SC's Avatar
Do it anyway. Modded or not, it will add life to your trans.
Old Jan 23, 2009 | 02:21 AM
Sharkey's Avatar
the type of cooler is important. beleive it or not, by overcooling your transmission you decrease life. the tranny and fluids are designed to work at a certain operating temp, too low and the oil is too thick, too hot and the oil breaks down. there are 2 basic types of coolers
tube and fin
this is basicly a long tube with fins around it, just like the radiator on the back of your fridge. these work good on older transmissions (think turbo 400). tthe problem with them on newer vehicles is that they can overcool the tranny and not allow it to get to operating temps, cauing lockup clutch issues and weird shifts.
stacked plate coolers
this is the cooler style you want. it is much more efficient, and its whats reffered to as a self regulating cooler. the way it works is it orfices inside it, close to the inlet/outlet they are large, and as you go farther away they get small. when the fluid is cold it goes through only the bottom section of the cooler, as it warms up it uses more of the cooler as the oil can flow through the smaller orfices. this allows you to put a large cooler on to compensate for high loads and keep the tranny cool, and allow it to get into the proper operating temps.
when finding a cooler you need to make sure it has the correct size fitting on the lines or you could get leaks. also proper size also needs to be considered, id recomend something along the lines of this one from b&m http://store.summitracing.com/partde...5&autoview=sku . its 3/8 line and you should have no problems fitting it on a cobalt.
when installing the cooler, you will want to install it in series with the radiator, and have the fluid flowing from the tranny to the rad, then the cooler, then back to the tranny (ill post this info tomorow on what line is feed andd return). most coolers come with plastic straps that allow you to tie them directly to the rad or a/c, i recemend against this unless absolutly nessesary. the kist usualy also come with metal brackets, try to make them work to solidly mount the cooler to the car. plumbing isnt as straight forward as it used to be with tranny coolers due to the special fittings car makers use. if you cut a steel line, make sure you flare the end of it, then slide the hose over and clamp it with 1 hose clamp (never double clamp a hose). this will prevent the hose from sliding off or leaking. you could also cut a rubber hose and use a barb to barb fitting to allow you to join 2 hoses.
Old Jan 23, 2009 | 02:26 AM
PenguinPIE's Avatar
so whats a good auto trans temp? mine runs at around 120 -165F i've seen
Old Jan 23, 2009 | 04:41 AM
operating temperatures are usually around 180*. 160-170 is better for your transmission in making it last longer. Anything cooler will usually just increase drivetrain losses. our transmissions hold a LARGE amount of tranny fluid (ive heard from 11qts to 14qts depending on if its a drain or a full flush of the tranny), so it takes a while to get to operating temperatures.
Old Jan 23, 2009 | 09:06 AM
Sentry's Avatar
Even if you're not running boost, it's a good investment for your car, plus you can get one at any good parts store for < $40.
Old Jan 23, 2009 | 09:11 AM
biniecki's Avatar
Also if you are running or ever plan on installing the B&M shift+ this is a good thing to think about installing. Its on to do list
Old Jan 23, 2009 | 12:04 PM
im running the tube and fin style for 2+ years with no problems and operating temps are fine.
Old Jan 23, 2009 | 12:34 PM
red06SC's Avatar
Oh, I didn't know you could overcool these. I just know DSM transmissions were very bad for running hot...
I'm kinda new to this whole GM thing.
Old Jan 23, 2009 | 03:59 PM
im up to one year for mine. Tranny is great
Old Jan 23, 2009 | 05:45 PM
PenguinPIE's Avatar
really? 180F?
because on my daily drives i can barely make it above 120...it just doesnt get hot
Old Jan 23, 2009 | 05:50 PM
sport08's Avatar
yeh i read a post i think Maven made he said 180* for auto tran operating temp
Old Jan 23, 2009 | 06:23 PM
Originally Posted by PenguinPIE
really? 180F?
it takes a good amount of driving to get 14qts of fluid to reach 180*. anything less than 20 minutes probably wont get near that temp...
Old Jan 23, 2009 | 08:41 PM
yeah on my way to work which is a 20 minute drive, my temps are always pretty low. longer trips evens it out to around 180.
Old Jan 23, 2009 | 09:26 PM
Maven's Avatar
For long life, proper efficiecy, etc, etc.....trans temps usually like to be 170-195, temps as high as 230 or so wont harm anything(though extended perriods of time over 200 do shorten the lifespan of the fluid by about half) On street/daily driven vehicles I like to put the cooler in the hot line from the transmission BEFORE the factory cooler. This way the aftermarket cooler does the most good, but you wont run the risk of overcooling the fluid, as it will still go through the stock cooler in the rad to stabilize the temps at the 170-195 zone it likes to be in.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
Shane H
Sep 20, 2015 11:56 AM
