Automatic 2.0
I know there was a guy on here who made his turbo 2.0 into an automatic...i tried searching multiple different things, and nothing came up. I do know he used the transmission from an hhr. What my question is, is it the 2.4 transmission or the 2.2?...Any useful info is appreciated...
turns out a sensor was grounding out causing the car to hit limp mode.. had nothing to do with anything about the auto trans if i remember correctly
your an idiot
the op was talking like he didnt know the lnf was in the hhr,
and he asked if it was the 2.2 or 2.4 transmission that was used and i was stating they use the same transmission
your an idiot, get a life, quit trollin, it makes you look pretty pathetic
I am not saying, I am just saying...
Also the 2.2 and 2.4 did have different transmissions on:
LS/LT 2.2 Hydramatic 4T40E automatic transmission have 3.63:1 final drive ratio (38/34 tooth chain drive, 3.05 gearing)
SS 2.4 Hydramatic 4T45E automatic transmission have 3.91:1 final drive ratio (38/34 tooth chain drive, 3.29 gearing)
Now the 2.2 and 2.4 did have the same manual transmisssion which was the Getrag F23
So please guys stop being so mean to people when you dont even know what you are talking about yourself
Sorry for my rant OP i am just getting sick of the way this site has seem just gone down hill with people helping and just has turned into people hating
i'm not saying.. i'm just saying..
they found out when they were taking the trans out because they though the whole harness needed to be redone and the kid just wanted his car back after months of it sitting.. turned out the harness was fine just the map sensor or something was grounding out
So just like when you try to sell your procharger kit. You know how to fix the problem that was holding you up. But what about the other problems that you did not hit yet?
You are really dumb. Fo real.
the harness was tested/ double/ triple checked
the auto tranny setup worked great.. there are vidz on youtube of them doing 14 psi pulls with it.. it would just close the throttle after 1 pull and would only let them hit 5psi or something till they shut the car off. idk all the specifics i'm just going on what i remember of what paul told me last time i was at his place lol
