which axle side gets destroyed??
Old Oct 17, 2008 | 09:19 AM
stangthang's Avatar
When people break an axle at the drag strip, or even on the street, is there usually one side or the other that breaks?? Is this something that could be repaired at the track if it happens?? I was thinking about finding an extra used set to take for back-up, and would have an extra for anybody else at track also...ideas??
edit: are both axles the same?? maybe this was a stupid question....would a replacement axle fit either side??
Old Oct 17, 2008 | 09:22 AM
alleycat58's Avatar
It depends on whether or not the car has limited slip. IIRC on an open diff in the Cobalt, the passenger side is the drive wheel, so that would be the axel to go. On a car with LSD, it's anybody's guess.
Old Oct 17, 2008 | 09:32 AM
mperez's Avatar
A Buddy Of Mine Broke His Drivers Side Axel. And It Toke About A Couple Of Hrs To Fix. AND HAS NO LSD
Old Oct 17, 2008 | 09:35 AM
stangthang's Avatar
thanks for the replies... I have LSD....so either side could go??
Old Oct 17, 2008 | 02:13 PM
Hockeyman's Avatar
when my friends axle broke, it was his driver side. He has LSD.
Old Oct 17, 2008 | 02:15 PM
alleycat58's Avatar
Didn't mean to say it's impossible. It's possible, though significantly less likely, to break a driver's side on a non-LSD car.
Old Oct 17, 2008 | 02:16 PM
Axle Man's Avatar
i broke my drivers side a few days ago
non g-85
Old Oct 17, 2008 | 02:44 PM
mperez's Avatar
I Guess It Might Be A 50/50 Chance Either Or
Old Oct 17, 2008 | 02:47 PM
SuperchargedSS's Avatar
Either.
Old Oct 17, 2008 | 02:51 PM
Axle Man's Avatar
on a non g85 trans the drivers side will break more than likely g85 its a toss up
Old Oct 18, 2008 | 04:36 PM
stangthang's Avatar
are the axles the same on both sides?? I have only seen pics of them out of the car, and they LOOK the same.....If I got a spare axle, could it be used on either side??
Old Oct 18, 2008 | 04:51 PM
lsjwannabe's Avatar
i broke both
Old Oct 27, 2008 | 05:23 AM
burntorange's Avatar
I have an LSD and blew both! :0 hahahahhaha I ripped the knuckles apart on the passanger side, and broke the driver side axle in half lol
Old Oct 28, 2008 | 01:15 PM
cobaltssredtint's Avatar
i broke the axle on the driver's side and i have lsd
Old Oct 28, 2008 | 01:41 PM
arkkornkid's Avatar
same here, back on the 17th
Old Oct 28, 2008 | 01:42 PM
Vetteman-sssc's Avatar
No matter if you have LSD or Not .
The Axles Suck Period !!!
And Break or Click ....POS
Old Oct 28, 2008 | 02:18 PM
stangthang's Avatar
maybe somebody can answer a question I have been asking.... are the axles different lengths?? or are they the same on both sides?? Also, where to get a replacement set?/ I saw a member selling used ones for $200 ?? Then I saw someone mention you can get replacements for around $149 ?? They are probably re-conditioned??
Old Oct 28, 2008 | 08:55 PM
qwikredline's Avatar
i got shafts the outer cv and shaft no inner brand new or complete from 100 bucks...same both sides
Old Nov 4, 2008 | 02:07 PM
asdkidz-06ss's Avatar
ya i broke passenger side over 5 times found out its cause the extension housing was all jacked up and ive got lsd
Old Nov 4, 2008 | 02:08 PM
hatrickstu's Avatar
all 4 of mine (2 lsd, 2 not) were broken on the driver side, right behind the wheel hub.
Old Nov 4, 2008 | 02:10 PM
ColeJJones's Avatar
Bannned
my buddy broke his drivers side... twice
Old Nov 4, 2008 | 10:57 PM
fix the darn wheel hop. PM me for the solution this is ridiculous...by the way, drag racing on street tires at 36 +psi is silly it will make hop worse...
hatrickstu you are one smart fast dude so you should fix this....
Last edited by qwikredline; Nov 4, 2008 at 10:57 PM. Reason: Automerged Doublepost
Old Nov 5, 2008 | 07:21 PM
stangthang's Avatar
Well, I have poly tranny and engine mounts to install, but axles can still break, correct?? What should I lower the pSI to at the track if I run stock tires for now??
I was only trying to figure out what I should be paying for a set of used stock axles, and wanted to know what else I could buy (new) that would work....thanks
Old Nov 5, 2008 | 07:49 PM
poly mounts do diddly for hop. thats my opinion based on my testing. the psi is lowered to change the spring rate in the tire, as it lets the tire sidewall flex more and helps combat hop. There is a reason real drag slicks have "wrinkle walls" doncha know? no pm no more answers I ahve used axles for 50 complete, new (complete but no inner joint) for 100.00
Old Nov 5, 2008 | 08:06 PM
Jeremy360's Avatar
I'm not sure about DSS Stage 2 axles, but as for the stock axles, both sides are the same piece, the passenger side just has a small, removable rubber boot at the end for the intermediate shaft. I've only been through 4 on the driver's side because of a loose mount, so I've used both.
