axles limits
Old Mar 7, 2007 | 02:46 PM
cgss's Avatar
axles limits
i tried searching and came up empty handed. so like the title states what are the limits to the stock axles?
Old Mar 7, 2007 | 02:51 PM
memphisr24's Avatar
Depends, you can break them on a stock car very easily (wheel hop + sticky track). You can push 350 whp no problem on these axles, however, the first time you get wheel hop/use slicks, forget it.
Old Mar 7, 2007 | 02:55 PM
cgss's Avatar
well all i have is in my sig. what i wanted to do was a port job and some tranny mounts and h.e think i will need axles?
oh and a 2.7 maybe
Old Mar 7, 2007 | 03:24 PM
06blackg85ss's Avatar
limits of stock axles... = stock power...
sorry man, but thats the deal..
they may take a bit of punishment for a while... but not much..
Old Mar 7, 2007 | 03:27 PM
shabodah's Avatar
Axles are real similiar to rear ends in older cars. If you launch from a complete standstill a lot, they won't be happy, but if you let the car roll 2 mph so the lash is taken up, they do pretty well.
Old Mar 7, 2007 | 03:33 PM
eh mine broke on a roll
Old Mar 7, 2007 | 03:35 PM
Ljavy17's Avatar
not from a 40whp roll right?
Old Mar 7, 2007 | 03:38 PM
CobaltBurst's Avatar
this is rare....
your fine as long as you dont wheelhop or hook up at the track....
but its one of those things just ride on them until they break....
Old Mar 7, 2007 | 03:42 PM
I was also putting down 296whp... I was pulling out onto the track and tried to clean off the tires. (don't let you go around the water box at atco, bu no means a burnout, just a roll out)... didn't work so well.. made it home about 20 hours later... and missing a chunk of my thumb (long story)
Old Mar 7, 2007 | 04:26 PM
chevytech007's Avatar
Has anyone broken the upgraded axles? Maybe on slicks?
Old Mar 7, 2007 | 04:31 PM
I haven't yet.. but I will try
Old Mar 7, 2007 | 04:35 PM
i was looking at the axles when i was putting my intake on... they didnt look incredibly hard to change. What do you think?
Old Mar 7, 2007 | 04:47 PM
there very easy to change!!
Old Mar 7, 2007 | 05:45 PM
Halfcent's Avatar
I'm old school
Axle swaps are pretty easy. Mostly just remove and replace. You may need an alignment afterward since you unbolt the strut. On the FE1 struts (base model Cobalts), the holes aren't slotted. But I hear the FE5 struts (SS/SC) are.
Old Mar 7, 2007 | 07:48 PM
sleepin06's Avatar
where is a good place to get upgraded axles ?
Old Mar 7, 2007 | 07:53 PM
Shortbus's Avatar
driveshaftshop.com, you can break the stock axles from stock power up, doesnt really matter if you have all the mounts, and bars in the world, you hook, hope, turn the wheel wrong, shift hard, one time they will go, my friend in his redline broke his doing a burnout at the track, he had bwoody solid motor mounts, and bwoody traction bars, its going to happen one day, so might as well get them before it happens.
Old Mar 7, 2007 | 08:21 PM
celicacobalt's Avatar
is this so true on an automatic car? i have zero wheelhop right now but im not sure what will happen at 270whp
Old Mar 7, 2007 | 08:25 PM
Halfcent's Avatar
I'm old school
Automatics are less likely to snap an axle because there is no clutch. Power is engaged to the wheels at the clutch, and then the lash through the trans creates a torque spike at the axle. With an auto, the wheel brakes are what hold the car still, so the lash and torque are already through the axle, greatly reducing the possibility of a snap.
Old Mar 7, 2007 | 10:38 PM
2K5SS/SC?'s Avatar
2-3 hops on a launch will do them in on a stock car. Trust me I know! DriveShaft Shop Axles FTW!
Old Mar 8, 2007 | 01:45 AM
chipmonk212121's Avatar
you can take them to a local axle shop and have them put upgraded parts on the inside and will cost less than 200$. I found a place that did my grand prix buddy's axles and they work phoenominal! they are gonna charge me 100$
BRAND NEW UPGRADED AXLES FTL
thedriveshaftshop charges so much because they have to purchase new axles to install the hardened parts in.
Old Mar 8, 2007 | 01:49 AM
BlackWidowSS07's Avatar
Yeah, I snapped my left axle from that exact reason and launched at 2300 rpms, so you just gotta be careful with em. As my boys called the Cobalt its a "show room axle breaker" if you arent carefull
Old Mar 8, 2007 | 01:09 PM
cgss's Avatar
damn where are the cheapest axles?
Old Mar 8, 2007 | 09:33 PM
Maxim_X's Avatar
Hmm... Im geussing GM doesn't warentee something like that. They probebly say abuse or something right? Has anyone tried or gotton axels replaced under warentee??
Old Mar 9, 2007 | 05:26 AM
given i had to tell a white lie about exactly how i snapped it, i got mine replace under warranty, that and the car had less than 1500 miles on it too
since then i havent even THOUGHT about going back on the track, these stock axles suck major @$$ though I have heard that putting the Ingall's Torque Dampeners will help reduce the chances of breaking them.
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
