Benefits of double clutching??
I've been wondering what are the actual benefits of double clutching? I mean well it takes a little longer but is there any benefits during daily driving or racing? I don't know if its really worth it cuz if ya fck up you can say
to the tranny.
I've tried double clutching during normal driving and it seems a little more smooth however, i would think the slave cylinder would wear out twice as fast...
Anyone care to elaborate on this?
to the tranny. I've tried double clutching during normal driving and it seems a little more smooth however, i would think the slave cylinder would wear out twice as fast...
Double clutching is only really useful on downshifting, as it lets you match the revs of whatever gear you're downshifting into, and so you're already making more power when you start moving under the new gear. That's why racecar drivers do it, so the car isn't bogging down when they come out of turns.
It really came about when there were no synchros on transmissions and unless you rev-matched, you were going to grind gears. So, it helps with saving your synchros on downshifts.
Not under the right conditions.
Some road racers and rally drivers will double clutch on an up shift in a corner to better control the power going to the ground.
But for our cars and typical driving, yeah... your best not to double clutch an up shift.
Example: Going from 3rd gear down to 2nd gear, put in the clutch all the way, give a quick rev up to about 3k rpm (varies on how fast your going) let off the gas and then let clutch out while revs are still up, resulting in a smooth downshift
I thought that was called rev matching!!! ****! I have been doin it wrong all this time. Well can u now explain rev matchin to me.
Double clutching (down shift example)->
- Let the engine reduce the speed of the car.
- Clutch and take car out of gear.
- Release clutch.
- Rev to matching engine speed for new gear.
- Press clutch.
- Put car in gear.
- Release clutch.
Notice the two clutch presses.... hence 'double clutch'.
- Release clutch.
- Press clutch.
- Put car in gear.
- Release clutch.
There's another step to actually double-clutch as opposed to rev-matching:
1. Press clutch in
2. Shift to neutral
3. Let clutch out
4. Blip throttle to reach desired RPM's
5. Press clutch back in
6. Shift into gear
It's the extra step of letting the clutch out before you blip that's the difference. Saves wear on the clutch plates IIRC.
EDIT: Dangit Omega you beat me... lol
1. Press clutch in
2. Shift to neutral
3. Let clutch out
6. Shift into gear
Ahhh ok.
I often find myself doing this.
Press clutch in
Go from 5th to 3rd while foot is still on clutch
Tap gas to desired RPM (around 3500)
the let clutch out and mash the gas
Poor clutch.....
Press clutch in
Poor clutch.....
rev matching is usefull. not only does it reduce wear on syncros it also helps reduce wear on the clutch as the clutch isnt trying to pull the engine rpm up when downshifting.
double clutching is pointless. it is the norm for old trucks that are non syncronised, you had to do this to get the gears to match rpm. howerver, in the 50s they came up with syncros, a device that does the rpm matching for you. if a transmission has syncros, all you are doing by double clutrching is putting extra wear on the clutch and related components.
can you double clutch when coming to a stop and just go through all of the gears? I know when im stopping, I dont put the car into neutral, I just hold the clutch down and move to the desired gear (usually only 1 lower) after I hit or rev to my desired rpms. Even when racing. is that wrong?
