Benefits of double clutching??
no, there's no need to double clutch at all on a modern transmission. basically, to keep it simple, back in the day you had to double clutch because the gears were all seperate. if you were in first gear, when you shifted to 2nd, you were physically disconnecting the gears, and putting the next 2 sets of gears together. if the engine and transmission weren't spinning at the same speed, the teeth would not match up and grind. with modern trannys, and what's called synchros, the gears are always together. so you can just hit the clutch, shift, and let the clutch out. in other words, in new trannies the gears never actually disconnect from each other like they used to.
if you were to go in first, shift fast to 2nd, and dump the clutch, the car would jump forwards and give a nasty lurch. that's because the engine and tranny are not spinning at the same speed, and all of a sudden they're forced to go the same speed. however, the gears won't grind. before synchros were used, you oouldn't do that, and that's why you had to double clutch. hope that makes sense.
rev matching is usefull. not only does it reduce wear on syncros it also helps reduce wear on the clutch as the clutch isnt trying to pull the engine rpm up when downshifting.
double clutching is pointless. it is the norm for old trucks that are non syncronised, you had to do this to get the gears to match rpm. howerver, in the 50s they came up with syncros, a device that does the rpm matching for you. if a transmission has syncros, all you are doing by double clutrching is putting extra wear on the clutch and related components.
Well lets just say my buddy that drives a rustang... his version of double clutching-
1-Pull out of gear into neutral
2-Push in clutch
3-Select gear
4-Drop clutch and give it gas
Obviously he is an idiot... he does drive a mustang.. lol. But anyways I rev-match all the time, but never really see the need in double clutching.
later
2-Push in clutch
3-Select gear
later
Oh and D4 I believe you were refering to the term "constant mesh."
hmm, maybe some one needs to post some vids of this phenomenon.
found a video on youtube double clutching, you guys tell me
doubleclutching
doubleclutching
Last edited by artawesome; Mar 12, 2008 at 09:15 PM. Reason: Automerged Doublepost
But 2 gears and the dogteeth are still spinning at engine rpm or lower so it does help with them locking in with syncros. It is not needed but there is no real reason not to. If you do it do it, if not dont, it doesnt really do anything unless the tranny is already slipping dogteeth.
