Breaking in new clutch??
Old 03-21-2008, 11:46 PM
Sufu's Avatar
I just got my Spec Stage 2+ installed, but I'm not exactly sure what is the best way to break in a new clutch? This is my DD, but I do like 90% highway to work. Anyone have some good advise?
Also, it seems to be very hard to get it into reverse, kinda like it doesn't want to go in at all unless I force it in. Is this normal for a clutch until it's broken in?
Old 03-22-2008, 12:42 PM
qwikredline's Avatar
no, shift cables may need adjusting...and did you install a new OEM slave cylinder/release bearing...not a lot of success on this forum it would appear with the spec clutch stuff. Dont shoot the messenger...drive it normally thats all the break in you need. Normally= NO slam/power/fast shifts, NO jack rabbit drag strip launches etc...good luck
Old 03-22-2008, 01:08 PM
Sufu's Avatar
I installed the GM OEM bearing, which I got from CED. Otherwise, it grabs and drives fine except for Reverse being a bitch and not wanting to go in.
Old 03-22-2008, 01:41 PM
TurboTechRacing's Avatar
Drive nice for AT LEAST 500 miles, dont open it up for around 1,000 miles, it should be well done after that
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
ineedacobaltss
11-07-2015 02:25 PM
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: Breaking in new clutch??
