Clutch Engagement Issue
Hey everyone,
I've racked my brain on this one and hope someone can help out. I have a 2007 Chevy Cobalt SS/SC and had no issues with my clutch engaging over winter. When Spring came I keep having this issue where the clutch pedal even when fully pressed doesn't allow me to shift into gear. I do have a short shifter I don't know if its maybe a linkage issue? No loss of brake fluid, so I don't think its master or slave cylinder. I've also purged the lines with fresh brake fluid for the hydraulic clutch and bled for air twice. No change still. If I "pop" the clutch pedal I'll get back full pedal and can shift. I get tired of "popping" my clutch pedal to get into gear especially if I'm hammering it. Any ideas anyone?
When I say pop the clutch pedal, I mean I depress it partially and side step it. This gives me full pedal again and I can freely shift gears. This issue happens in any gear. The clutch pedal has pressure at about 1/4 of it depressed. If I do the popping, I'll get immediate full clutch pedal. If the seals are weak any to fix this or does the master just need replaced at that point? Thanks everybody.
Magz_rule
Sep 18, 2014 01:38 AM
