clutch fitment
clutch fitment
I have doen alot of searching around and keep finding different results. My question is will the gm lsj clutch kit ( flywheel, PP, and clutch disc) bolt up to a 2.2 and work with the f23 trans?. exedy claims that the input splines are both 14 and overall disc diameter is onlo 13mm bigger witch is not that significant. I have also read on hear that the input splines are not the same between f35 and f23 trannys? Any help would be great REGUARDING my questions not telling what clutch I should buy UNLESS you know it wil not work.....mabe just the flywheel will work? or just flywheel and PP with a stock disc for my application?
